2010 Escalade HID headlights in a 2010 Yukon Denali?
Robert Sparks
Kentucky
I have a 2010 yukon Denali and would like to put in the 2010 Escalade HID headlights with the side LED running lights. Is this possible? If so where to purchase the healights / ballasts, how to wire them to function with the DRL. I know the Yukon has the DRL the same as the main head light which would seem to be an issue. Any advice would be greatly appriciated.
stevek
Dallas, TX
the Esky headlights are a little skinnier than the Yukon headlights. Only way to add them to fit right, is to change the hood and grille I believe.
R
Robert Sparks
Kentucky
Well that is disappointing. I really want HID and the DRL to work. I see so many cars out there today that cost half of what I paid to the Denali that have OEM HID. Plus the HIDs in my 305Z reach out twice as far as the Denali. I really like the look of the LED side markers also. I am open for all input as to the best option. Thanks….
---------- Post added at 12:10 PM ---------- Previous post was at 11:40 AM ----------
Does anyone know if the projection low beam is as good as the stock low beam? ie can you see as much down the road? See on the ones in the like below.
http://shop.ebay.com/i.html?rt=nc&Mo...=p3286.c0.m282
UofMZ71
like said, you would have to change the basic front. with that being said, the factory esky lights will run you $2k. All the wiring would work, but i would think you would be better off trading in for one...
you can have the HID and DRL work, just might go through some ballasts.
stevek
Dallas, TX
Well, I am sure you can find the parts for the grille and hood. I have straight black so I could find the hood already painted. I could get the grille and change it to an aftermarket. Headlights would just be the most expensive probably.
zach2011
Platinum Member
Escalade headlights are pretty expensive, but I don't see why you would want to put a Cadillac fascia on something that isn't a Cadillac. If anything I'd go with Steve's idea because at least you're not branding your vehicle something it's not while still getting the new headlights.
stevek
Dallas, TX
Maybe get a T-rex or some other similar grille, I like the look of them. I may do this actually. It's possible I can get enough cash and buy all the crap and install. I REALLY want these lights on the Platinum:
http://www.cadillac.com/escalade/gallery/
zach2011
Platinum Member
They come at a hefty price of about $1600 each, but they looks so good! And actually, I have seen some "grade A" used Platinum lights on car-part.com go for about $500 so it helps to check.
stevek
Dallas, TX
25975452
25947497
25957702
15907627
15791866
15907623
25901978
15907625
15907626
25948814
25948815
11609465
11515638
11609385
11610055
Part numbers for all the front bumper components and no grille^
15945915 - hood
25897649, 25897648 - L&R headlights
25819549, 25819548 - L&R Fenders
10383562, 10383563 - Fog/turn signals
$4,604.25 for everything and the HID's, no grille. Grille is another ~$300 if I remember correctly. Many of the bumper components may be replaceable with the ones under the Yukon bumper, but this is the cost for all that new.
zach2011
Platinum Member
Good info, is this price of $4600 at GMPartsDirect.com?
stevek
Dallas, TX
Anyone know if the Escalade and Denali/Yukon have the same hood? I believe with 99% certainty that the fenders are the same, but I don't know about the hood.
GM Customer Service
Michigan
Hello,
The hoods are not the exact same on those two vehicles. There are a few differences between the two. Please let me know if I can be of further assistance.
Geoff Allen
GM Customer Service
stevek
Dallas, TX
Hello,
Geoff Allen
GM Customer Service
Are the parts on my previous post correct? What all is the same on those two that wouldn't have to be changed?
zach2011
Platinum Member
Steve, are your parts for Platinum or base models?
And the hood is different only because of the headlight shape.
stevek
Dallas, TX
I don't remember, I think only the base. I know the fenders are different because of the vent, but would they fit otherwise?
zach2011
Platinum Member
They'll all fit, but I know that at least for a Tahoe you have to change out the inner fenders as well (not sure if you have that listed), though a Yukon's inner fenders may be the same.
stevek
Dallas, TX
Yep don't have the inner fenders listed. Are those side vents stick on? I don't see them having any functional use
Drewphil
