2008 Yukon Denali - 11,000 miles on replacement engine - Manifold issues?
fellowgearhead
Michigan
The motor was replaced in our Yukon in December of 2011. 13 months and 11,000 miles later, I brought it back to the dealership. This time for an oil leak, an engine noise on cold start and a coolant smell.
Their diagnosis (so far):
- oil leak is from the oil pan gasket
- engine noise on cold start is from the manifold gasket (they haven't actually taken it apart yet, could be more?)
- coolant smell - unknown. Initial pressure test is fine.
Odd things I have noticed
- the coolant smell is from the front exterior of the vehicle. No noticeable coolant leaking under the hood, no real loss of fluid in the fluid levels.
- I *swear* that I am getting antifreeze in the driver's side door jamb. Repeatedly. It is wierd.
-Car does not overheat in hot weather. It warms well in cold weather. We have a lot of crazy weather in Michigan and it has been fine.
I was told by the dealership that it is common for there to be problems with the manifold gasket. My question, wouldn't that have been replaced with the new engine? Should I be having this many issues?
Thanks! Kim
From rebuilt engine and transmission (twice), to replaced components: http://www.tahoeyukonforum.com/forum/showthread.php?t=31122
CKendrick
