2007 Yukon Denali Suspension Issues Resolved
Seapro
South San Francisco, CA
In 2015 I decided to purchase a bigger tow vehicle to tow my boat. I purchased a 2007 Yukon Denali with 144,000 miles on it. Since owning this Yukon I have been constantly having the "Check Suspension" message every time I tow or go on long distance rides. I have changed my air compressor, air shocks, compressor relay, all the auto leveling sensors and just recently the suspension control module. I finally have not gotten any suspension messages after towing my boat 20 miles. I am writing this to maybe help someone that was or is having the same problem I had. I changed the air shocks after checking if they held air and they were leaking and after changing them and starting the Yukon they did not pump up. I found that the 40 amp fuse was blown to the compressor. I replaced the fuse and the pump still did not come on so I pretty much knew the pump was dead so I replaced it and the shocks pumped up. i thought I was good to go, wrong. I towed the boat a couple of weeks later and on the way home I got the suspension message again. I started looking at every wire and sensor I could find for the suspension and I noticed a snapped leveler so I decided to change all four of them. I got another message the next time I towed the boat. I only had the electronic suspension module left to check. When I dropped the spare tire down I saw that the module had been removed off the frame and was just hanging there. I brought the module to the dealer and paid to have it checked and it was fried. I replaced the module and haven't had any problems with it since. Hope this helps if you are having the same problems.
Great writeup!
Did you do the ALC trim set recalibration (auto level control), after installing the new ESCM?
Seapro
Seapro
The module has to be programmed before it is any good. I purchased the module online and had GMFLASH program it. It is a bear disconnecting it from the harness so be careful. You can have the dealer program it on the vehicle but it is expensive.
X-ray Nerd
