2007 Yukon 5.3 Flex fuel supply line
QDaddy
After smelling gas and getting worried, I decided to drop the tank and take a look... WOW. My fuel pump was wrecked with corrosion and a line just about to puke. The only way to remove the fuel supply line from the hard line was to cut off the connector, so I am screwed. I REALLY don't want to pay the $50+ bucks for a new line when all I need are the connectors, so I hit Amazon. I have found some Dorman connectors, but there are too many to choose from. Could one of you gurus please clue me into what size connectors I will need to get my Yuk back in the green?
It is the fuel supply line (larger pipe on a 2 pipe fuel pump) that runs almost straight down to the metal fuel supply line where it connects with a 90° elbow. My understanding is it is a 3/8" line, 3/8" connector at the fuel pump and 5/16" 90° at the metal hard line. How am I doing? Any help, tips, or suggestions would be greatly appreciated.
Just to add a bit more clarity...
http://www.wholesalegmpartsonline.c...DRXL-SLE/PIPE-Fuel-Line/2990539/24100442.html
Q
QDaddy
Through trial and error, I have found that both connectors are 3/8" just in case someone else has this issue.
Now the new question is.... where to get a replacement hard line going up to the injectors? With all the manipulation and corrosion, mine has cracked.
contraption22
I am just about to go through this myself. Could you provide the Dorman part numbers you used?
Thank you.
Luggz
