2007 Burb Z71 coolant question
Phibbs87
Phibbs87
Greenwood, Arkansas
Coolant level now after only driving it 6 miles to and 6 miles from work
Gunna attempt to burp it
Phibbs87
Phibbs87
Greenwood, Arkansas
Tried to burp didn’t hear anything
But after running the heat, the ground under the engine bay
looks like you probably have a leak at the firewall where the lines connect to the heater core, usually they just break off but they sometimes crack and leak
check right here for leaks
Phibbs87
Phibbs87
Greenwood, Arkansas
So looking this is the only “source” location I found but it’s not dripping, just wet.
I rubbed the T connectors and didn’t feel wetness
then you need to grab a flashlight and slide under the truck and follow the wet trail up, if it's not at the firewall then it's on the hose going to the water pump, or the water pump is seeping, or the overflow tank is cracked or a radiator hose is leaking or the radiator is leaking, you just need to get under it and take a GOOD look with light. if it's leaking from the engine block that's bad news but that's not very likely.
looking at your picture it looks like it is coming from in front of the crossmember, wind and gravity will carry it back from wherever it is leaking in front of that.
Phibbs87
Phibbs87
Greenwood, Arkansas
So this is the 6 month extended warranty that was included. At first glance I’m not sure if I should just use this to get it fixed. I prefer to fix myself but this will save the headache too
Phibbs87
Phibbs87
Greenwood, Arkansas
Yeah but there’s a lot in front of the cross member lol why can’t this ever be easy haha guess that’s the main fun of the chase
if you have leak in front the fluid may not leak there it may stick to the surface and then drip down much lower
it could be the water pump, but you need to get way up under the truck to see, the water pump is pretty much dead front center on the engine you can see your hoses connected to it on the passenger side, one hose t-s off and goes to the radiator and back to the firewall
where it t-s off from the water pump it has a plastic part that sometimes cracks too, you can grab it and give a wiggle and see if anything comes out
JPeter
