2005 Yukon SLT- Brake Fluid Change
Dantheman-2003
Placerville, Ca
Any issues on this model Yukon changing brake fluid? I read somewhere about ABS and sensor issue when changing brake fluid out.
Thoughts?
Thanks!
Dan
Bill 1960
Testing the Limits
You’ll have more issues in the long run if you Don’t change it. Water contamination and corrosion, boiling under heat stress.
SnowDrifter
Washington. The desert side not the Starbucks side
Nope. Just don't run the master dry
If you don't have traction control, there's a central rear line that branches at the axle. That is to say, first rear wheel will take a while to get clean fluid. Second rear wheel will happen fairly quickly. So no, it's not just you :p
You'll need about 32oz to do it.
16 to drain/refill the reservoir before you start. And another 16 to get clean fluid on all 4 corners
agmanw8n
