Ryanz71hoe
- Joined
- Aug 30, 2019
- Posts
- 10
- Reaction score
- 1
Received an email back from blackbear telling me i have a pretty sizable vacuum leak because my throttle % is at about 2% average, and most tahoes with that engine run at about 5-6% throttle to maintain idle, and in addition i have a dead O2 sensor, passenger side upstream.
Before i even went through the process with blackbear, i was already tracing down the infamous "rough idling" and it drove me crazy because the truck basically picked and chose when it wanted to do it. We found no vacuum leak, after checking on a few different occasions. Anyways, we came to the conclusion the problem was the fuel pressure regulator (built into the fuel pump). Now i'm running about 1.2 % throttle after changing the fuel pump (changed with AC Delco). do i have to relearn the fuel pump somehow? how do i get my throttle back up if i cant find a vacuum leak? maybe there is one but me and the 2 other mechanics that checked couldn't see it?
i sent the new data to blackbear, but figured i check on here too while i have time on a sunday. before anyone responds, here's what i have already done to the engine -
Replaced MAF Sensor (OE)
Replaced throttle body and added throttle body spacer (both JET Powr-Flo)
Replaced fuel pump, filter and pressure control built in
new AC Delco plugs (iridium ADO-41-110) and 10.4 MM Taylor wires
hypertech 180 thermostat
Powermaster street alternator (165 amp)
yellow top battery
both AC Delco Knock sensors and chevy performance wiring harness
new manifolds (both sides)
Corsa Exhaust system
Spectre performance air intake kit
yellow top battery
