2002 Chevy hd hood
bigdog9191999
sw michigan
the short answer is no.
the angle at the headlights is off a little, i know some do the swap but you have to cut the corners a little for headlight clearance. but i would have to do some research to be sure exactly what.
It's possible, just need to know what you're doing.
Fosscore
The ultimate HD hood thread. 30 pages should answer darn near every question you have and get to Young28 Yukon from a few years back.
Fosscore
Oops ^^ I didn't look far enough ahead and see that you found the thread I posted above. It can be done, just a bit of work. Kind of like the front clip from HD to non-HD. Work arounds with some fiddling to make it yours. Good luck. Plenty of info and knowledge to pull from on the TYF.
ComputerJAM
I looked through the thread you mentioned, and several other locations on the web. But i haven't found an answer (or missed it).
Does anyone know if a trade back and forth is possible? As in, would my Suburban hood fit back onto the HD pickup?
There are a couple HD trucks near me, and i would like to offer to swap hoods (with cash), if this will work.
They're def interchangeable.
Yes. The reason you didn’t find any reference to that is because nobody wants to swap from a HD hood to a non HD hood. Maybe cash will entice someone.
ComputerJAM
Thank you! Yes hopefully the cash is a good incentive. There are a couple of gardeners in my area that may not care about the look so much.
Conedaddy
