2001 Yukon ABS / Brake lights ?
amaturejoe
Have had a problem for a while where the ABS and brake ligts on the dash will come on and stay on until you shut off the truck.
No real pattern to when they come on, sometimes it is with in the first mile or two and sometimes it is after 15 minutes or longer. For a while I swore it was when I hit a bump, but not a 100% sure that is it.
Hooked the truck up to a computer to see if the probelm was generating any codes, but nothing in the history.
Checked the sensor connections and sensors, everything looks good.
Has anyone ran into this before or have any suggestions what to check?
I am afraid to take it in for service and see what they come up with ($$$$$).
imi4tth3w
Texas
i can't believe i just found this. been looking since forever and was about to send mine in for 130$. this will save me big time
Macman45
Considered doing this as well. Doesn't happen much, but figured it must be a weak joint.
MightyMouse383
