2001 Chery Tahoe Brakes problem??
Dcrazys
2001 Chery Tahoe LS I am having problem with the brakes. if anyone have this problem? because I never had something like this before. what happen was my brakes line broke and I replace the line and bleeding it out also use scanner to do ABS Bleeding too So when not running pumping the brake and it got hard to press the brake feel good the brake BUT the min, I start up the Tahoe and put my foot on the brake and it goes right down to the floor? I also repeating bleeding the brake while not running pumping brakes then got hard no leak full brake fluid again start up the Tahoe brake goes to floor again? what the hell going on here? Master cycle or booster or whatever? please help me.
Happy Thanksgiving everyone
rockola1971
Indiana (formerly IL)
You got air trapped in the rears likely. Bleed the brakes with autobleed with vehicle RUNNING. Be prepared to find one particular brake caliper that all of sudden spurts alot of air after 3 or 4 cycles of bleeding. For my Tahoe it is usually passenger rear that is the guy.
You can park downhill and get the rear higher or you can jack the rear up off the ground a reasonable amount of height and this all will facilitate getting the air pushed out of the ABS manifold and to the calipers.
Doublecheck that replaced broken line for leaking. If its leaking fluid, its sucking in air too.
Scottydoggs
NJ
the master went dry when the line was busted, you likely have air trapped in the master. bleed the master by pumping the pedal and cracking the line nuts like they were a bleeder valve on a caliper. then do the rest of the bleeding as you have been. make sure the master does not go dry while bleeding.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Air is somewhere in that system for sure. Patience and repeated bleeder screw openings in your future. Keep that master cylinder full.
BeenChevy
Minnesota
Wonder if this guy ever got it figured out. I changed the brake lines on the 01 Yukon and lost pressure to the front calipers. Oddly enough even after MANY ABS bleed proceeding I pump the brake pedal 5x and crack the drinker side bleeder and fluid will move up my tube a few inches and stop. This is the same for the driver side front. I've also tried running the abs bleed and cracking the bleeder 1 at a time at all 4 corners each bleed attempt (pedal down) - no air, just fluid. The pedal is still way spongy. Went out a drove up hills down and abs stopped many time and the pedal feels like it gains a bit more but then when I gett'er back the front calipers putting off no heat meanwhile the rears are of course real warm. Any pro tips? Master never ran out of fluid and When I replaced the two lines between it and the abs I swapped em in quick. Also ran a rubber tube to a line fitting up at the master 1 of 2 ports at a time and pumped the pedal with the other end of the tube in the reservoir to confirm no air. Any recommendations for trying to manually bleed the abs by cracking one of the two line fittings on the bottom of the abs module or is that a no-no?
Andylbc
