2.5" Level and fitting 20x10 -24
Mighty Hd
Florida
I have a serious bug to get new wheels, which will require new tires obviously.
Specs:
13 Z71 4wd
Current: Zone 2" level, will be swapping to CCM 2.5 front level
285/65/18 duratrac tires on Z71 stock wheels
Bilstein 5100 @ stock height
Front bumper is trimmed
So what is truly necessary to fit a 20x10 - 24 wheel with 33x12.50x20 tires? I keep reading LOTS of conflicting statements all over the place. CustomOffset.com has a number on there ---some say major trimming, others say no rubbing at all.
Looking at the XD Heist or Fuel Contra
Thanks
Big Mama
Virginia
Does it run now? The new tire is .43” taller and 1.3” wider but the wheel is wider than that and the offset changes moving the wheel out more. If you turn your truck to the left and look where the inside is add about 1.5” forward to that if I did the math right. Which is questionable
M
Mighty Hd
Florida
Fits fine with the 285s on the factory wheels. The only thing I had to do was take a zip tie and pull the front wheel well liner back towards the bumper.
I was just curious how old these people are running these wide tires and rims. Considering a -18 or -24
Big Mama
Virginia
Right. Like you said lots of trimming and rolling front fenders. I believe even without the offset 32’s will rub being over an inch wider than your current tire.
X-ray Nerd
