2/3 Drop Traction Control Light
wot_denali
UaE
This my first post here and i can tell you what was the prob ,i had my denali lowered by ground force for more than 2 years and i have this prob for almost 2 years i went to the dealer many times and the answer was go back to stock ,but one month before i found what was the prob ,there is an small eloctronic peice located above the brake pedal i think it is a brake switch ,by this part the signal will go to the pcm ,there was a fualt reading coming from this part and if do not replace it you will notice that if press the brake pedal the brake light will not turn and also if this part get more losen you will not be able to move the trans pedal from p to r or so ,it cost me only about $20 i will get the part number for you soon ,this what i experienced with my denali
turboeclips
Austin, TX
get an alignment...problem solved. i have done 3 of these 2/3 drops and only one had the lights come on. after alignment it was fixed. btw im a GM tech
sounds like that's the solution... I need to quit being lazy and get it aligned.
Durobans
