2/3 drop or 3/5 drop
FrankU
Babylon New York
American _Sheepdog, Your Tahoe looks great. Got the same only not lowered & 17"s.
Originally wanted to go with just a rear lowering but , now thinking of going with Norcals 2/3-4 lowering cornering setup with air bags too. She will be doing some towing.
Why will I go with Norcals setup ?
Forum supporting vendor, he helps put this show on
Check around he has a lot of support in the community
Yea....I could find cheaper , experience tells me not to go down that road again. Been trucking (Tahoe isn't exactly a truck) 4X4 & drag racing for over 40 years.Go with a proven setup , a lot less B/S .
Enjoy gentlemen !
ABNLT
LaCrosse, Wisconsin
I put in the 2/3 kit purchased from Norcal and absolutely love it. Just the stance I was looking for, still rides great so the wife doesn't have an issue with it, no tire rubbing, and goes through the snow like a mad man.
MooseKuckle
Dallas/Fort Worth
I need to replace shocks on my 2007 Tahoe but plan on a 2/3 drop in a month. Should I hold off on replacing them due to the suspension change or does it even matter?
NeverSatisfied
eBay Baller
Wichita, Kansas
majority of 2/3 drop use the factory shocks and shock extenders, so most likely if you need new shocks you should probably just get them
NORCAL SS
SUV SUSPENSION GURU
I have a kit that
I sell the lowering struts 2 inches
NORCAL SS
SUV SUSPENSION GURU
Tony, what would you say is a fair price for an install of your basic 2/3 drop kit?
with cutting off the bumpstop bracket... spinldes/rear springs/shock extendes/swaybar endlinks im going to say 5 hours max
NORCAL SS
SUV SUSPENSION GURU
for denali its different
front my strut mod
front spindles
rear you will get 3.75 out of my set up 3-4 kit
KBones
Quick question..why do the Belltech 4" lowering springs have so many coils and the Mcgaughy's have about half as many?
NORCAL SS
SUV SUSPENSION GURU
Progressive rate springs and ride better. This is why I don't sell the mcgaughys rear anymore
Doug Gilreath
I too am debating a 2/4 drop. I was planning mcgaughys spindles and belltech 4" drop springs. Question, do I need axle relocators or shorter sway bar links? (2007) I am going to do shock extenders and shorter shocks on the rear.
NORCAL SS
SUV SUSPENSION GURU
in rear i have the set up for 360 shipped with is springs/bumpstops/extenders/endlinks and free travel mod is required
Jefro Shmo
2/3 drop worked for me on 24"
Denali2k8
I need to stop reading these posts. I really wanna do the 2-3/4 drop on my 08 Denali. Ugh...then I'm gonna wanna do swaybars and that whole kit I saw. $1k easy put the door, wife might kill me right now
SidewaystheSeven
Same here
Sent from my LG-H901 using Tapatalk
Woned2004
