1999 Red OBS 4dr Tahoe owner
movado750
Just picked this one up a couple weeks ago. Original owner with 253k, Well taken care of, but the steering is a bit sloppy. I've been doing some research and it is across the board on fixes. This is a clean truck wow, spent some time in the garage with her last night....uffdhaaa. what a red head....
Miami-Dade
Moderator Supporting Member
Welcome from NYC&Miami!
That is one AWESOME find! To find a 1 owner in that condition is like finding a needle in a haystack. Congratulations!
drakon543
easiest thing to check is your pitman and idler arms as they can be checked visually on the ground. another easy visual check is above the steering box is a coupler with what is basically a piece of tire being used as the actual coupler. if the pitman arms are moving and the tires aren't change those. also if the upper part of the steering shaft is moving and the lower isnt change that coupler. everything else will be your end links or a worn steering gear box.
exp500
Get a helper to turn steering wheel back and forth, put a big wrench on steering gear coupler or vise grip shaft. Wobble steering wheel feeling for play. That eliminates everything before steering gear worn. Then crawl under truck and look at all the tie rods, idler, pittmann while helper gently rocks wheel.
M
movado750
A few more...I'm still amazed, the back seats,,,,,
M
movado750
It really should not be driven in a salt winter hear in MN. anyone down south interested?
Miami-Dade
If you decide to sell it please put in the For Sale section. Not here. You will need to have at least 100 posts and be a member here for at least 180 days to post it. Those rules are here for a reason.
Spikedmax
Tighten your steering gear box 1/4" at a time and test. Do not tighten too much or you'll be installing a new gear box....which is probably what it needs anyway.
GMT800 2005 Tahoe Z71
Navy Supporting Member
IMO, the steering gear adjustments should be done in no more than 1/8th turn movements. I do agree that the box likely needs replaced anyway but the adjustments may do the trick.
Eickybobby5050
