1999 Chevy Tahoe broken throttle cable.
Ry_price
My throttle cable broke this afternoon, or at least I think its my throttle cable but regardless, when I start up the truck, the engine just revs at around 6. I found that my gas pedal was all the way to the floor and there was some slack in the line which I think is the throttle cable.
Has anyone had this problem and tell me how to fix it easily? Thank you1
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
You can check the throttle valve at the throttle body. See if you can rotate it back or see if anything is causing it to bind up.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
fix it to replace cable to find out if broke disconnect it from gas pedal and pull. if it comes all the way out, well.....
---------- Post added at 05:40 PM ---------- Previous post was at 05:39 PM ----------
btw idling around 6-700 is normal.
Thekenstar
