1997 Tahoe heating up
C_andy460
I have a stock 1997 Tahoe and she has started to run a little hot. I have checked fluids, cap, hoses and all is good. When going down the highway with the a/c on it just keeps going up and you turn the a/c off but it is slow to cool down. I am thinking it maybe the radiator. Any other ideas?
Andy
_Dylan_
STAY FROSTY
Take out the thermostat and put it in some water higher than 195 (if its 195 stat) and check to make sure its opening.
Fan is working?
WalterMitty
Oklahoma
Double check and triple check ur water level. You might have a leak somewhere.
And if you have a leak, the system won't pull the coolant back out of the overflow tank when things cool off. The overflow tank could show full and the radiator be half empty.
C
C_andy460
Happy camper
My Tahoe has stopped over heating...I changed (in order) thermostat, waterpump, anti-freeze, pressure cap, clutch fan, radiator. And the winner is...
top 7 rows of radiator
bottom 7 rows of radiator
dam thing was plugged up bad, and I had flushed it at 95,000 miles.
Andy
dizhai
