1996 chevy Tahoe dash light problem
bell5606
I was driving last night and my dash lights had went out does and body no what could have done that. All of the other lights are working fine but thought. Need help!
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
bell5606
bell5606
Ok thanks
---------- Post added at 10:04 AM ---------- Previous post was at 10:03 AM ----------
I just checked it's not burned out
SunlitComet
OBS Jedi-Do Good
unknown at this time.
do your parking lights work when head lights are turned on? if so then something is wrong with the head switch or rheostat inside. if not then the fuse "pk lps" #9 on same fuse block.
bell5606
bell5606
Yes they do. Ok thank you for all of your help
bell5606
bell5606
I have checked all of the fuses and they are all good and they still will not come on any other solutions
SunlitComet
OBS Jedi-Do Good
only one fuse left to check and then wiring or head switch. that is **** fuse "lighting" under the hood 50A closest to the battery terminal but if the head lights, courtesy lights, dome lamps, power mirrors and drls still work that fuse is fine. i would just go after the head switch.
bell5606
bell5606
Where is the head switch located
bell5606
bell5606
Ok thanks
bell5606
bell5606
Ok I have change the light switch and all of the fuses are good and I went as far as changing the gauge mount and it still doesn't work
SunlitComet
OBS Jedi-Do Good
then the only thing left is the wiring itself. is there any specific dash light that does and does not work? and what do you mean gauge mount?
bell5606
bell5606
No the only thing that does not work is the lights behind the gauges. What Isn't was the whole dash board is what I replaced.
SunlitComet
OBS Jedi-Do Good
i am sorry i did not quite understand that last part. so the gauge cluster nite lights don't work but all warning indicators do? and the lights in the radio and havc control head are fine?
bell5606
bell5606
Yep that is it all of the warning lights work and radio etc. Sorry I don't know what it is called I think it is the gauge face kit. I had bought a new one and the gauge lights still didn't work
SunlitComet
OBS Jedi-Do Good
oh you mean the cluster assembly then. with the cluster removed the connector has two grey wires. both have a yellow wire next to it. you want the one that has a yellow on one side of it and a tan/white wire on the other side of the gray wire. when the head switch is on and the dimmer put on full brightness (but not interior courtesy locked on as is not needed) you should see system voltage on the wire. if socket is numbered it would be cavity 29. after that illum fuse the output splits into 10 different wires on of which goes to you cluster for illumination.
bell5606
bell5606
Oh Ok yea that is what I ment
dizhai
