'09 Yukon Aux Input Reroute?
martinneallewis
Hey guys. This may be an obvious question, but here goes. I have an '09 Yukon XL with the Bose nav package. I want to use my iPod, but I hate how the auxiliary input on the head unit is on the front of it (top front right). Is there a way to reroute the aux input, or plug into the back of the unit without having to spend the ~$100 on a PAC interface while still maintaining the factory radio control functions?
bauer4567
Allentown, PA
Dremel and duct tape??
No, but I do not believe this is possible...
Just from having the radio out a few times, you will see how it is built into the cd slot... If you are brave enough to open up that unit and do some soldering, I bet it is possible, but I wouldnt want to try it!
cody08
Kansas
You can solder onto the back side of the plug. If you have a volt meter that does continuity you can use it to find out which wire is which.
briannorris
