lakaw
Hello all. I've been lurking for a few weeks and wanted to post my upgrade components for some feedback.
My goal is to keep the interior looking completely stock, so obviously I will be using the stock HU. I also want all stock functionality ie Onstar, XM, Bluetooth, chimes, etc over the audio system. Oh and the delayed power on after you turn the ignition off.
Front components: Boston SPZ60
Rear components: Boston Pro60SE
JL Stealthbox replacing the factory Bose sub
JL Cleansweep OEM Interface
JL Cleansweep Signal Summing Interface (I'm not sure I need this, but my installer said I would)
JL HD900/5 amp
The Boston SPZ's are rated at 150w RMS with 3 ohm impedance. The Pro60SE's are rated at 125w RMS, also with 3 ohm impedance. The Stealthbox 10w1v2-4 is rated at 300w RMS. Hopefully I picked the right amp, but I'm not positive. The HD900/5 will output 75w RMS X 2 @ 3 ohms for the front and rear channels with 500w RMS X 1 @ 4 ohms for the sub.
I was hoping to remove the Bose amp and install the HD900/5 in it's place. My installer spoke with JL and they recommended that I leave that amp as is. I don't know, maybe they plan on using it for the center and rear D-pillar speakers.
Has anyone done anything similar?
I have Captains Chairs in the second row, so I was planning on mounting the amp on either side. Under the second row is a flimsy feeling, shallow, carpeted cover. Does anyone know if I can cut a hole in that to recess the amp slightly while giving me a firm base to mount the amp to?
And what about speaker wiring? Would I really benefit from new runs? Or is the factory wiring satisfactory?
JL HD900/5 amp
