"08 Z71 Tahoe Oem Struts?
EddieC
Looking to replace our original front struts and it seems that conventional and monotube struts are listed by aftermarket manufacturers but I can't find any information on what our Z71 was originally equipped with. Anyone know? We liked the way it rode from the start as GM intended so we're not looking for a significant change.
EddieC
EddieC
So monotube was original on Z71?
One GM parts site notes front #540-573 for a 2008 LT; no specific listing for Z71.
akbrener
Baltimore, MD
Can you still see a label at the bottom of your strut with the part number?
Those numbers I got were kind of a quick search and after reading it seems that they didn't do too much different on the shocks like they used to on the z71. If yours are black then I assume they probably are the same strut and any LT.
EddieC
EddieC
The front struts are red and original. No obvious labels on the struts and the finish is significantly deteriorated. Worth another crawl under there though.
The original window sticker noted Z71 option with "Off Road Suspension".
I did find a press release that noted "high pressure struts".
PPV12HOE
NC
Only factory ac delco fronts I can find that are red...
540-472
540-579
Take a look at your rpo codes for suspension numbers... should start with a 6 or a 7...
EddieC
EddieC
540-472
540-579
I see 6TJ and 7TJ. How do I use that?
Your part numbers show "monotube" which I have read have "high pressure" so it seems to be adding up. I was considering KBY replacements that come fully assembled and they have a monotube option.
EddieC
EddieC
Thanks for chasing that around.
EddieC
EddieC
Yours by rpo codes listed would be 540-579...
Rock Auto has them for $83.79...
Wish I had the talent to assemble the strut assemblies. But now that I know the shock type it helps in chasing down fully assembled aftermarket units.
EddieC
EddieC
Swapped out the struts today. Glad I found this helper in the garden. Seems they multiple here.
pt1965
columbia,sc
my 2010 had the original red rancho's on it at 165k when i got it. i changed fronts to bilsteins set at the highest level to replicate the ranchos that had a 2" leveler. and i put monroe air adjusts on the rear to level it back out when i am towing a heavy trailer.
ride is awesome!
EddieC
EddieC
ride is awesome!
Define Awesome.
Durobans
