Has Chevy ever figured out why the Hybrids stall out? I'm tired of bringing mine into the shop, getting expensive repairs, and then the next time I'm driving it, it stalls at a light. Nearly had a bad accident in stop and go freeway traffic on the Atlanta perimeter, and now I stalled turning left onto a highway right after dropping $1700 to "fix" the problem.
Enough! There is something wrong with this model. I've replaced the battery too many times now too, like other here.
you need to find a real mechanic seems like they guy your taking it to is pulling you leg and stealing your money..... I'm lucky to have a legitimate mechanic he is really good at what he does... and he does hybrids most mechanics are afraid to work on "hybrids" because of the HIGH VOLTAGE
350 volts DC is nothing to worry about IT's AC or
alternating current is something to worry about..
He works on them other wise I would not buy it....
I know the stall thing you are talknig about it happened on a 2009 i test drove I did
not buy it .. It was unexpected and almost caused a crash..
it lagged from the electric to motor switch over...
on the 2008 2wd I Bought does not experience this issue.. it has 84,100 miles on it
V4 and v8 and electric the 3 modes works smoothly as well as smooth translation from electric to engine mode and v4 or v8
as well as the lifters are smooth (it had frequent oil changes they really took care of it tell the could not pay the payment any more)
I just wish I could adjust some options on when it "auto stops" the 25mph auto stop cut off is too low I wish it was around 35mph when you take your foot off the gas this would work very well since my local speed limits are mostly 40 to 60mph in my area (live in the desert) it would be way more optimized for me...
it works fine when it's cold out the engine was ice cold last night we had a low of 30F and snowed and it fired right up did not even struggle..
if you are having issues with starting up I would check the
MASS air flow sensors use the correct cleaner for mass air flow and ALSO check the air filter make sure it's clean
you should be diagnosing this at a start up issue rather then a hybird drive issue
How to Fix a Car that Cranks Too Long
