BSarteSr
- Joined
- May 2, 2010
- Posts
- 211
- Reaction score
- 46
So i have had this '07 Yukon XL Denali since 2009, done brakes all around on it several times, always do ceramic pads with new rotors.
I noticed that the rear pads wear out sooner than the front, also that the passenger rear wears faster than the driver side too.
I have several older ('60's, '70's, & '80's) show cars, most having front disc with drum rear, so they are setup to use more front brakes than rear.
My question is there something different about the '07 Yukon? Is it setup to use the rear disc's before the front? Other wise I might have any issue with the proportioning valve?
Getting close to needing a new set of pads and rotors all around, so I need to plan my attack!
