07-14 PPV shock / strut part number verification please :)
domoarigato
Hello PPV'ers,
I'm looking to replace the suspension struts and shocks this winter on my 2011. Hoping to find the source of this weird vibration I'm getting, and I'm thinking the shocks / struts may be a part of it. (Already replaced the u-joints in the driveshaft, rebalanced tires, trans mount and AFM delete is on the way)
From my understanding Monroe is the OEM manufacturer of these parts. When I put my VIN into GM parts direct it pulls up all the suspension options but I think I've narrowed it down.
Can someone verify these part numbers for me before I order?
Front: MONROE 39106
Rears: MONROE 911545
Also anything I should know before I jump into this? I will have a spring compressor handy for the fronts. I believe the rear is a separate shock / spring assembly.
Thanks in advance for any info!
Ron C
Los Alamos, NM
Hello PPV'ers,
Front: MONROE 39106
I was actually wondering about that, if PPVs, SSVs have different shgocks than 'civillian' Tahoes do. Since PPVs are lowered (right) and there seem to be SSVS (like mine) that actually have a bit of a lift, factory.
thanks,
Ron
D
domoarigato
thanks,
Ron
Hi Ron,
From my understanding, the fronts on the PPVs are the same (the tire size is what gives it its lowered appearance). However for the rear it uses a different strut / spring than the conventional models. I'm not sure on the SSV's but maybe someone can chime in.
RichardCranium
Mebane, North Carolina
thank you. just to clarify, you replaced OEM PPV suspension with something different? and these were the OEM part numbers?
Correct, these were OEM I attached photos of. I replaced all 4 corners with Belltech when my truck was lowered.
To answer your questions about the differences, the spring rates are different on the PPV......as are rebound rates on the shocks. You'll find the shock absorbers fit other vehicles, which was the source for the difference in rates for the PPV application. So the lowered ride height is in the spring difference, which is about a 1" difference from a LS-up Tahoe.
D
domoarigato
Awesome. Thank you.
How do you like the belltechs? Worth the upgrade? To do the shocks at all four corners Im already looking at ~300... I dont want to change the ride height if possible, but if the ride quality is improved I could justify going the belltech route.
RichardCranium
Awesome. Thank you.
Its improved drastically, but my PPV had 180k miles when I changed mine out. Everything was original and tired. When speaking on terms of the ride of a PPV, the new ride is great with the Belltech shocks and new rear springs. The biggest difference is going to be with the tires though, I went a tad bigger with 265/70's in a Continental. Best decision I ever made, and I have zero regrets about the tires or suspension.
if you have magnetic ride control then these are the oem part for the front 580432 (580-432)
rockauto has the best price, plus there is a sticky for 5% off
D
domoarigato
My mileage is up there as well. I couldnt find any documentation showing if they were ever replaced. At this point I think any shock replacement, whether OEM or aftermarket is better than nothing.
Love how the larger 265/70's fit on your PPV. Seems to fill up the wheel wells much nicer. How much more of a drop was the belltech kit over the factory PPV suspension, if any?
PPV's dont have mag-ride I believe, I'll check rock auto. Thanks!
k09viper
