05 TAHOE A/C Recharge
ge0rgin0
EL CHUCO, TX
I want to replace all those components to do a full robust A/C system recharge.
Its an 05 TAHOE w/ rear A/C.
It was working fine, air just got hot now. No leaks im sure of but will check. Compressor is engaging
So far:
-Bleed Old Freon
-New Freon & Lubricant
-Use of Vac Pump
-Front Orifice Tube
-Rear A/C Expansion Valve
Wat else?? Thanks
Scottydoggs
NJ
the blend door actuator may have taken a dump on ya if the compressor is still turning on and off and you dont see a nasty wet oil mess at a joint along the system.
retiredsparky
The blend door only affects the front temperature. If both front and rear are not cooling, then you are going the right direction. Did you do a leak test with a leak detector or add dye when you charged the system? Possible leak locations are the front seal of the compressor caused by either an overheating clutch or a bad bearing, tubing to hose connections, condenser coil, either of the two evaporator coils, or an o-ring that has shrunk from old age at the tubing connections to the compressor or other components.
OneofFew
Talullah Falls, Ga
So far:
-Bleed Old Freon
-Use of Vac Pump
-Front Orifice Tube
Wat else?? Thanks
So your A/C is working fine and no leaks... so... I don't get it. Those are not maintenance items.
BlacktopBandit76
