04 Escalade rear diff gasket
Tamcphail89
my rear diff is leaking on my 04 escalade awd. I'm trying to find the correct gasket....anyone that's changed it before have the part number? Also what fluid should I use to fill it back up?
Thank you
Did you plug your VIN in over at GMPartsDirect or GMPartsKing? AWD should have a regular old 10-bolt 8.6" axle. It takes 75W90 Synthetic Gear Lube, the current AC Delco part number is 10-4016 and it takes 2.15 Quarts.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
ESCALADE ESV AWD
GM#15284314 W/ 8.625 $149.89
GM#26063649 W/ 9.50 $23.85
GM#26067159 W/10.50 $23.85
ESCALADE AWD
GM#15807693 W/8.625 $22.38
T
Tamcphail89
I got the Felpro gasket today for the 10 bolt. Just gotta get the fluid and change it out.
.thanks guys
T
Tamcphail89
What gear fluid would you recommend? I'm changing it out tomorrow after work so it'll be to be something I can get at autozone etc.
Thanks
SnowDrifter
Washington. The desert side not the Starbucks side
I've used whatever 75w90 synthetic fluid is on hand. valvoline, mobil 1, etc. I get the stuff with the friction modifier built into the fluid - just fill and go.
Checking it is a little bit annoying - you need to fabricate some sort of dipstick. Fill spec is is about an inch below the fill hole. 2.1 quarts
01ssreda4
i put the cheapest crap available in all my rears that i build. Cept the camaro, its got redline shockproof. And when i swapped gears like 6 months later, you better believe i saved it and put it back in.
him__chase
