03 lowered tahoe
oOooOo
I just lowered my 03 Tahoe 3" in the rear ,should I have used the djm relocation sway bar end links as well???I haven't driven it yet.but it doesn't look like a full 3" drop ,it was late and dark...but the more I read up on the issues sounds like a good idea..any help would be appreciated...and is there an alternative to the 170 $ kit of jdm
Big Mama
Virginia
Check with Tony Norcalss on here are you hitting bump stops or anything underneath? Did you use lowering springs? 3 inches isn’t usually enough to cause problems
O
oOooOo
3 inch in the rear only new shocks ,22 inch rims..I hear a scraping sound on some bumps..I looked and it scrapping the plastic..dropping the front 1 inch this weekend...the look is great the ride is way better just don't like the rake..not use to it I guess
05Single
afraid of the dark
Do you have autoride? Is it metal to metal scraping? Metal to plastic? Rubber? Scrapes on only bumps? Hard turns ? Both?
Big Mama
Virginia
It’s rubbing the top of the rear inner fender? Are your bump stops gone?
O
oOooOo
Tire against plastic...I did not remove the bump stops.it scrapes on turns and bumpy roads..I can feel around the tire and feel where the plastic scrapes the tire...it's not horrible..just annoying as heck
O
oOooOo
Big Mama
Virginia
Have you pulled the plastic back? Look behind it for parts the don’t move then drill 2 small holes and run a good zip tie through and pull it back. On my front end I did that in 3 or 4 places.
Tahoer2008
