03 escalade navigation question
Mbz03
Hey guys I have a 03 escalade with bose system none navi can I put a oem navigation into it any DIY thanks
Mr. 960
Yup!!! I'd spring for the TNR 800 touch screen. Just make sure you get the one that is listed for the LUX amp. You will need the GPS antenna that you can just use double stick tape and attach it to the a/c duct immediately to the right of the radio, once radio is removed. Lastly you will need the map disk. Let me know, and I can provide you with the latest part numbers. Shop around on Ebay for the best deals and or package deals.
Mr. 960
M
Mbz03
Thanks Miguel! Can u find me part numbers that be great and this unit is plug and play? Thanks
Mr. 960
Yes! Just make sure it is the LUX bose radio. I can't think of any part numbers off hand as they were superseded many times. Just get the touch screen radio. I believe the latest number is 15800001 or something..... check this link out http://www.gm-trucks.com/forums/topic/92889-the-how-to-guide-on-installing-tnr800/
http://www.performancetrucks.net/fo...ps-201/oem-navigation-upgrade-gmt800s-496180/
Should get you started. Again, search ebay and don't be excited to get the first one. With patience you can get a clean one with rub free buttons for around 300.00 and change.
M
Mbz03
Miguel I found this one part number 15204334 it Saids on the back gmt800 NR
---------- Post added at 07:36 AM ---------- Previous post was at 07:34 AM ----------
Oh yeah I'll take my time but that one I just sent you the part number off is local and he wants $140 for it but wanted to ask you first see if it works on my escalade
Mr. 960
a quick search yielded that it is indeed a LUX radio. I'd call the dealer and double check. It is a good price, but it is not touch screen. Also due to having buttons along both sides, the screen will be smaller. Are the butons clean? If so, and if you don't mind not having the touch screen then I guess go for it.
TallHoe 96 OBS
