02 z71 4x4 problems continue. New switch, new encoder, same problem.
Dino009
Have you checked the fuses? How about some info on your vehicle?
Yes i pulled out the trec fuse and the ecm and replaced em both even though they were fine. I have a 2008 tahoe LT
Check #67, a J Case fuse in the underhood fusebox, if you haven't already.
Dino009
Yes i replaced that exact one. How about disconnecting the battery ? Would that reset it ?
Dino009
I wanna try everything i can before i take it into dealership.
Might get better/more suggestions if you keep this to a single thread, and not have multiple ones.
you say you cleaned the harness up and pins, but did you do the same on the opposing end (module? side) I would try spraying it with maf cleaner or electrical contact cleaner I would image they are both pretty much the same thing, it just evaporates and leaves no residue. if you do that and the it resolves the problem then go back and apply di-eletric grease in the harness to keep it from happening again.
Dino009
So none of that worked. Disconnected the battery hoping for a reset but nothing. Im debating of putting the old TCCM in just to see if that has communication. Then i know i gotta take the car in to get it programmed
Just noticed these last few posts are posted in the wrong year forum.
Dorman makes a replacement TCCM that has a learn procedure after installation. I'm not sure if the no-communication issue with yours would be corrected but it might be worth a try.
Lbris21
