02 z71 4x4 problems continue. New switch, new encoder, same problem.
Ialsofkdyourdad
Hey sorry for posting so much
So I have swapped the switch, no change
I swapped in a new encoder motor and cleaned the connectors ( no corrosion just wanted to be thorough) , no change
Before the encoder motor and cleaning I had c0308 and c0327
With the new encoder I had c0308 and c0323.
I put the old one back in and I have the same codes ( c0308, c0323) so I returned the new encoder as that clearly wasn't the issue
So I'm thinking it's either the tccm or the wiring harness. Can I get a tccm from a junk yard? I have a pick and pull near me and they have about 14 4x4 sierra 1500s from 2000 to 2002 and 2 tahoes so I was thinking if I go to one of the ones that was in a bad accident the tccm is probably fine since the truck died from impact.
Plus they only charge 20 bucks for a module.
So if it's not that what else could it be? A new harness is a last resort as I imagine that's a huge pain in the ass and expensive as well.
If neither of those are the problem Ill be at my wits end with the 4x4. Maybe rip out a manual transfer case from a base model Silverado and retrofit a manual switch. At the junk yard a transfer case is only 150 bucks
PNWYukon
Olympia, WA
Parts reviewed at the Warranty Parts Center (WPC) have a 75% No Trouble Found (NTF) rate. The only two legitimate reasons to replace the TCCM are:
^ Diagnostic Trouble Code (DTC) C0550
^ NO Communication with a scan tool.
Diagnostic Aids
^ When diagnosing a transfer case electrical control system, ALWAYS check power and ground wiring first.
^ Test the connections for intermittent or poor connections, complete plug insertion, bent pins, pushed out terminals and water contamination.
Pay particular attention to the terminal connections at the module. Spread or open terminal connections may create an intermittent contact. Do a pin drag test. Refer to the terminal testing information in the table shown.
^ After repairs are complete, ALWAYS clear DTCs from the module prior to a system function test. If codes are not cleared first, the system will not function after repair. The technician may erroneously think that the system is still down and that further repairs are needed.
I
Ialsofkdyourdad
Diagnostic Aids
I did clear the codes. And I cleaned the ground points under the driver door. I removed them and brought them back to bare metal with a grinder, reinstalled them and painted over the bare metal( if there are others please let me know)
On the encoder motor connections I spread all the pins out so they made good connections, sprayed them with alcohol.
I had asked priviously for voltage at the module and I haven't been able to find that info.
I
Ialsofkdyourdad
The reason I'm thinking the tccm is I saw someone on a Silverado forum having the same issues as me who fixed it by replacing the tccm
PNWYukon
Olympia, WA
Ground locations
If your plug looks like this then there are two reference voltages:
I
Ialsofkdyourdad
Thanks for the advice on the ground locations. I figured since its easy to swap and a cheap part I would try the tccm, and it fixed my problems, lights are back on the switch and the service 4x4 light is gone
Dino009
When you swapped out the TCCM, did you disconnect the battery and did you pay attention to connect the 4 pin connection last ? The reason im asking is because i replaced my TCCM but now have a “loss of communication with TCCM” code and none of the lifhts stay lit after starting car.
Have you checked the fuses? How about some info on your vehicle?
