02 Tahoe died on my way to work.
S
sniperwolfjs1
02 Tahoe
Hey guys I need some ideas to help me out. Changed fuel pump about January, while driving to work today and it just died and won't start back up. Any suggestions?
Sent from my SGH-T889 using Tapatalk
S
sniperwolfjs1
Hey everybody, just need a little help with this problem. I trying to figure out what's going on with my tahoe. I change fuel pump and filter around January of this year. Open to suggestions. Thanks
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Check for spark. If there's no spark, hook up a scanner and look for rpms while cranking. if no rpms, replace the crank sensor.
S
sniperwolfjs1
Hey guys sorry about answering so late. Had to pull a double shift at work a couple of nights and couldn't get back to you who had answered. Fuel filter was change. Would turn key to on position and won't hear fuel pump come on. Any suggestions? Thanks
Jons2005tahoe
Give it a shot of ether if it starts. It might be your fuelpump is bad
Sent from my iPad using Tapatalk
afpj
What brand fuel pump did you use when changed out? Several threads on here recommending sticking with OEM Delco, cuz if you go with cheap autozone no name it can fail quick.
Mlstammerjr
