01SLE
- Joined
- Mar 22, 2014
- Posts
- 71
- Reaction score
- 18
I've been struggling with this A/C for a year now. I put it on the back burner after last summer because I had a work around and had already put many hours and dollars into it. Summer is coming and it's hot in Phoenix.
The A/C didn't work when I received this truck in trade for rebuilding a transmission. The compressor was seized and destroyed.
I replaced the compressor, condenser, accumulator, rear expansion valve, and orifice tube. Flushed the lines, refilled.
A/C wouldn't turn on with cabin controls so I tried jumping the low pressure sensor and the other sensor on the drier (forgot the name of it) and no luck. Jumped the compressor at the relay and it turns on and it's ice cold.
So if I drove the truck last summer, I just jumped the relay. With a suspension/steering rebuild, oil pan, oil pump, etc last fall, I was tired of working on this damn thing and left it at that.
This year, I decided to replace the AC Heater controls in the cab because they don't seem to work right. Sometimes the controls would turn the blower on, sometimes it wouldn't. Sometimes it would switch hot to cold, sometimes it wouldn't. Plus it was an import unit in Celsius that annoyed me. So I bought a new one and installed it today and still no luck.
So I'm stuck. I understand the cabin controls send a signal request to the PCM to turn on the A/C compressor when you push the button. I understand the PCM only forwards that "ON" signal to the relay if certain conditions are met such as a positive signal from the low pressure switch and the other underhood safety switch on the drier (why can't I think of it's name?). But that's where I'm stuck. I don't know how or where to test the signals from and to the PCM.
Mechanically, the system is new and sound. It doesn't leak and it functions flawlessly with a jumped relay.
