05Single
afraid of the dark
- Joined
- Feb 26, 2015
- Posts
- 8,243
- Reaction score
- 11,639
I'd hit it
I'd hit it
I'd hit it![]()
Oops. Checked fuses ?Got in the Tahoe this morning and the radio is not workingso anyone following up on that hold off I may go ahead and just snip the plug on the amp to bypass it
It works but no sound again same issue as beforeOops. Checked fuses ?
The end result is nice. The biggest pain in the ass in this was fighting all the wires behind the radioSo far the only complaint on this is the screen hitting the gear shifter when I crank it. I may be able to go in the setting and change this I'll have to check into that
That's why I got rid of mine. Kept hitting the shifter, which got to be VERY annoying.
I had to break off that thick metal brace in the first pic to fit my double din.Thanks for chiming in Scotty inputs always appreciated. A little update on the radio ordeal yea the wire did come out of that little splice connector. As soon as I got it wired back in speakers started playing...now I'm still unsure if this way or cutting the wires at the plug is better for bypassing the amp. Anyways ran into another issues besides the speaker ordeal, I was losing power randomly. I took everything out of radio basket and looked around. Found that when it was pushed back and locked in the radio basket was wedging the plug on the back side of the radio. I did a little trimming and rearranging of wires and it's working. Fingers crossed hope I don't have anymore issues with it
After a little research this came of an Lh6 5.3 which came out in 05. It started in the Trail Blazers and apparently used from 07-09 on the trucks. To answer your question the TB on this intake is 87 mm ours is 78. Our TBs are also 3 bolt this one is 4 bolt. I could use an x-link harness to use the 87 mm but there $240 and that's just out of budget right now. The adapter plate is $40 to run your factory TBDefinitely keep us updated on your progress. What adapter are you talking about? Is the nnbs Tb bigger then the nbs?
The trail blazer ss intakes are a little different I thinkMine came off my buddies 06 trail blazer ss with the LS2 6.0. Mine looks a little different different, if that's the same intake.
This is my build thread man don't post stuff irrelevant there's a other places on this forum for thatAnybody has had any cluster problem ? Sometimes turn truck on cluster is off . after a few blocks cluster turns on . know where their might be a fuse for it ?
