Let's talk foam cannons
GalaxyBlackEsky
BlackedoutLT3
MD
I just washed mine in the middle of the day yesterday in mid 70s and was fine. I don't like to do this as I like to do it early in the morn but had some free time at work. What helps is also to get a good soap the is ph balanced so if the suds do dry they will not etch. My good friends Adams sells great soap. Here is mine yesterday mid soak after the foam cannon.
THE YETI
Director of Operations
South FL
I have a hose mounted one. It's ok. I don't mind just hand washing it tho. I should probably get a small pressure cleaner just for car washing tho. We wash the D every weekend. [emoji136]
DirtyBlackHoe
Thomasville, GA
I personally have gotten to the point that I pull out the electric pressure washer every time I wash the vehicle anyways, so the foam cannon doesn't really add much more "work" to it IMO. I had the foam gun and after using it for about a month, I never used it again. Just wasn't worth the effort to use it honestly.
that pressure washer that Yeti posted is an awesome deal and one of the better pressure washers for automotive uses on the detailing forums I am on.
Ben
PCB, FL
Anyone looking for a low psi pressure washer for their ride: Check out this deal:
AR Blue Clean 1900 PSI Electric Pressure Washer w/ Hose Reel - http://slickdeals.net/share/iphone_app/fp/150891
I did a lot of research on electric pressure washers after searching and making a purchase I would highly recommend the Clean Force 1400
http://www.homedepot.com/p/Cleanfor...m-Electric-Pressure-Washer-CF1800HD/203246923
It has a lot of bad reviews but that's because people didn't take care of it or prep it for winter in a garage that gets cold. IMO that's their own fault. No issues running 3 years strong now, plus the wand is the same style of a gas one which is really important because with most of those electric ones with plastic wands you have to engineer some sort of adapter for a good foam cannon to connect or a new wand all together. Just my .02
For example...
Where as my MTM foam cannon snapped right in out of the box.
THE YETI
South FL
For the price I just bought that AR blue clean. It's originally $200 on sale for $119 shipped 2-day air with Amazon prime. Couldn't walk from it and it came with a soap container for use as a foam cannon. I'll see how it works and if it doesn't work as anticipated I'll buy a different foam cannon.
This will come in handy when it comes time to clean the boat (when that happens).
Goodinblack
Goodinblack
I Like Tacos
Dirty South
THERE ARE 2 Different VERSIONS of the MTM Foam Canons.......
There is also a "Next Generation" version that Chemical Guys sells. That one is not in here.
This is the high pressure one. (GAS)
MTM Hydro Professional Foam Lance Adjustable with 32 oz. Bottle
http://www.wayfair.com/MTM-Hydro-Pro...3-MHD1010.html
http://www.amazon.com/Professional-F.../dp/B004GNZYY4
Features:
Also included is an instruction manual on how to get the most out of this great cleaning product
Disperses thick foam to up over 20 feet and at more than a 30 degree cleaning radius
Perfect for driveways, roofs, siding, even your car
Comes with a 1/4'' quick connect and a M22 fitting for easy attachment to just about any pressure washer
Spray pattern easily adjustable
Easily refillable 32 oz. bottle
For home or automotive use
This requires the washer to have at least 2.0 GPM and Over 1000 PSI pressure for use
Constructed from brass and high grade stainless steel for high chemical resiliency
90 Days warranty
This is the LOW pressure one. (ELECTRIC)
MTM Hydro Professional 2600 PSI Adjustable Foamer
http://www.wayfair.com/MTM-Hydro-Pro...9-MHD1109.html
http://www.amazon.com/Professional-2.../dp/B00EDSLVQC
MTM Hydro's High Pressure Adjustable Foam Lance 2600 with attached bayonet fitting is perfect for small electric pressure washers. Specifically designed for pressure washers with a range of 1.1-2.6 GPM and with a maximum pressure of 2600 psi, this foamer is ideal for washing cars, driveways, fences, roofs and walls. Produces thick, shaving cream foam up to 20 ft.
Features:
Attached bayonet fitting fits Karcher electric pressure washers
Also comes with 0.25'' male npt plug and 0.25'' male M22 fitting for most other pressure washers
Shoots thick foam up to 20 ft
Minimum pressure needed 1100 psi
Maximum pressure of 2600 psi
Minimum flow needed 1.4 gpm
Psi @ 2.6 GPM max
Perfect for small electric pressure washers
Brass fitting
I bought the LOW pressure unit and here are some pictures of it.
Goodinblack
Goodinblack
I Like Tacos
Dirty South
I paid 58.40 shipped and now it's 65 plus shipping Amazon. If you want this get it from wayfair. It's where mine came from.
VA929RR
YouTube Junkman. You'll find a wealth of information on products and technique. If you REALLY want to get your paint right (and keep it that way), start there. He has some of the best videos on cleaning, detailing and paint correction.
yates ™
Resident Apple hater
Iowa
So I forgot about this on my pressure washer and may not even be anything but figure I should ask, my washer has a spot for a bottle to mix soap in, will this work the same? If I buy the soap and a bottle, then use my existing fittings will produce the foam or is the tip the key?
yates ™
Iowa
Is that going to be a different tip than the four I have?
Bowtiebug
I have a craftsman washer and use the black low pressure tip for soap / foam and it works great , you shouldn't need anything but soap
MeanSlickCaddi
