98 Yukon - Police Package? Yes/No?
NRWhiteKnight
Kentucky
My in-laws scoped this one out for me and mom in-law says it has a police package on it. I did some searching here and found a thread that someone had asked how they can tell. I went to a site linked in the thread to look up RPO codes.
I know the GM lists SSV's for police service as 9C1's. But that is not listed in the RPO codes, though I am not sure if it would be. The first site I went to did not have a listing of all the codes. I found a second site which gave me info on those codes I did not find on the first site. I do, however, have a question or three.
1) The first site found this - code L31 : 409 CID V8 400HP (SPECIAL HIGH PERFORMANCE-SOLID LIFTER CAM). The second site listed it as a 5.7 liter (350) V-8. I know codes are subject to change over time, and my Yuk does have the 5.7L. Could it actually have the cam that's listed?
2) Code RL9 was not found on either site, does anyone happen to know what that code is?
3) These are listed on the bottom of the RPO sheet: U 9792, L 228A. What do these refer too?
Other than these things, I have no clue how to distinguish a regular Yukon from one with a police package. It's not super important, but it would be nice to be able to order the correct part when it calls for a different one than standard.
Love my Yukon either way.
TIA.
BattelWagun
Chi-Town USA
At the time OBS trucks were made, the L31 code was just the regular old 5.7. These trucks only came with three engines, the 6.5 diesel (very rare), the 350 vortec, and for the 2500 Suburbans a 454 was an option as well. The last two codes listed asre paint codes i believe.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
not a police setup but got some heavy duty cooling and large alternator setup in it. oh and heated seat comfy. and tow package.
UG1OPENER GARAGE DOOR, UNIVERSAL UNIVERSAL GARAGE DR OPENER(UG1)
UP0RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, CD, AUTO TONE, CLOCK, ETR. STEREO,AM/FM W/AUTO REV CASSETTE,CD,AUTO TONE(UP0)
UQ3SPEAKER SYSTEM,PERFORMANCE ENHANCED AUDIO ENHANCED SPKR SYS(UQ3)
VGCPROTECTOR FILM, PAINT ETCH PREVENTIVE PAINT PROTECTOR FILM(VGC)
VK3LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
VR4TRAILER HITCH(WEIGHT DISTRIBUTING PLATFORM) EQLZR HITCH(VR4)
VXSVEHICLE - COMPLETE
V22GRILLE,RADIATOR(CHROME) CHROME GRL(V22)
V54CARRIER,ROOF LUGGAGE(PAINTED) PAINTED RF LUGG CARR(V54)
V73VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
XGBTIRE FRONT P245/75R16 WOL R/PE ST TL AT 109S TIRE(XGB)
YD3AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE FRT AXLE(YD3)
YD6SPRING,REAR(BASE EQUIPMENT) RR SPRING(YD6)
YE9CONVENIENCE PKG COMFORT & DECOR LEVEL #3 COMFORT & CONVENIENCE PKG #3(YE9)
YGBTIRE REAR P245/75R16 WOL R/PE ST TL AT 109S TIRE(YGB)
ZGBTIRE SPARE P245/75R16 WOL R/PE ST TL AT 109S SPARE TIRE(ZGB)
ZM9SALES PACKAGE COMFORT AND CONVIENCE COMFORT AND CONVIENIENCE PKG(ZM9)
ZP6Unk.ZQ3DRIVER CONVENIENCE PACKAGE II(MERCHANDISING OPTION) DRVR CONVENIENCE PKG(ZQ3)
ZY2TWO TONE COLOR COMBINATION TWO-TONE COLOR COMB(ZY2)
Z82TRAILERING PACKAGE(SPECIAL)(REESE TYPE HITCH) PROVISION FOR HD TRAILER EQUIP(Z82)
Z88GMC TRUCK G M C(Z88)
1SEPACKAGE OPTION 05 (1SE)
1SZPACKAGE OPTION- (1SZ)
39UEXTERIOR COLOR,PRIMARY (39U)
EXTERIOR COLOR,PRIMARY,DK ADRIATTIC BLUE MET (39U)
52IINTERIOR TRIM LIGHT NEUTRAL (52I)
522TRIM COMBINATION - LEATHER, NEUTRAL (522)
55LSECONDARY COLOR EXTERIOR, LT AUTUMNWOOD MET (94) (55L)
6YBCOMPONENT FRT LH COMPTR SEL SUSP(6YB) SUSP(6YB)
7YBCOMPONENT FRT RH COMPTR SEL SUSP(7YB) SUSP(7YB)
AG2ADJUSTER PASS ST POWER, MULTI-DIRECTIONAL MULTI-DIRECTIONAL P/SEAT ADJR(AG2)
ADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER 6-WAY PWR P/SEAT ADJR(AG2)
AG9ADJUSTER,SEAT,6-WAY POWER 6-WAY PWR ST ADJR(AG9)
AJ1GLASS,DEEP TINT(REAR SIDE WINDOWS AND REAR DOOR WINDOW) DEEP TINTED GLS(AJ1)
AM7SEAT,REAR FOLDING RR FLDG ST(AM7)
AU0LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
AU3LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
AU6LOCK,TAILGATE,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL TAILGATE LK(AU6)
AXPVIN IDENT POSITION, MULTI- PURPOSE VEHICLE MULTI-PURPOSE VEHICLE VIN POSITION(AXP)
A31WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
WINDOW,POWER OPERATED,ALL DOORS PWR WINDOWS(A31)
A95SEAT,FRONT BUCKET,DRIVER,PASSENGER,HIGH BACK RECLINING FRT HIGH BACK RECL BKT ST(A95)
BVESTEPS RUNNINGBOARD, SIDE RUNNINGBOARD SIDE STEPS(BVE)
B34COVERING,FLOOR MATS,FRONT,CARPETED INSERT(COLOR COORDINATED) FRT CPT INS FLR MATS(B34)
B35COVERING,FLOOR MATS,REAR,CARPETED INSERT(COLOR COORDINATED) RR CPT INS FLR MATS(B35)
B39CARPET,LOAD FLOOR LOAD FLR CPT(B39)
B85ORNAMENTATION,EXTERIOR,BELT REVEAL MOLDING BELT RVL MLDG(B85)
B96ORNAMENTATION,EXTERIOR,WHEEL OPENING MOLDING(BRIGHT) WHL OPG MLDG(B96)
C25WIPER SYSTEM,REAR WINDOW RR WDO WPR(C25)
C49DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
C5UGVW RATING(6800 LBS) 6800 LB GVWR(C5U)
C60AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
C69AIR CONDITIONER,RR AUX RR AUX A/C(C69)
DD0MIRROR,O/S,R AND L REM CTL,ELEC,DEFOG,LT SENSITIVE O/S ELEC R/CON MIR(DD0)
DF5MIRROR,INSIDE,REARVIEW,LT SENSITIVE,COMPASS,O/S TEMP DISPLAY I/S REARVIEW MIR W/COMPASS(DF5)
DK6CONSOLE,ROOF RF CNSL(DK6)
D55CONSOLE,FRONT COMPARTMENT FLOOR F/CMPT FLR CNSL(D55)
EVATEST DVT, EVAP EMISSION REQUIREMENT EVAP EMISSIONS REQUIRED(EVA)
E55GATE,END END GATE(E55)
FE9FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
FG5SHOCK ABSORBERS,FRT & RR,GAS PRELOADED,DELCO/BILSTEIN,46MM S/ABS(FG5)
FK2ARM,TORSION BAR,SPRING ADJUST,LH TORS BAR SPR ADJ ARM(FK2)
FK3ARM,TORSION BAR,SPRING ADJUST,RH TORS BAR SPR ADJ ARM(FK3)
GU6AXLE,REAR,3.42 RATIO 3.42R(GU6)
JANPLANT CODE - JANESVILLE, WI, BOC JANESVILLE,WI ASSEMBLY PLANT(JAN)
JB6BRAKE SYSTEM,VACUUM POWER DISC,DRUM VACUUM PWR BRK SYS(JB6)
KA1HEATER - SEAT ST HTR(KA1)
KC4COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4)
KG9GENERATOR,140 AMPERE 140 AMP(KG9)
KNPCOOLING SYSTEM,TRANSMISSION,HEAVY DUTY HVY DUTY TRANS CLG SYS(KNP)
K34CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
L31ENGINE,GAS,8 CYL,5.7L,CPI 5.7R(L31)
M30TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
NA1EMISSION SYSTEM,LESS THAN 8500 LB GVW EMIS SYS(UNDER 8500 LB GVW)(NA1)
NF2EMISSION SYSTEM,FEDERAL,TIER 1 FED EMIS SYS(NF2)
NP5STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
NP8TRANSFER CASE ACTIVE, TWO SPEED, PUSH BUTTON CONTROL TRANSFER CASE(NP8)
NRQEXHAUST,CLOSE COUPLED CLOSE COUPLED EXH(NRQ)
N33STEERING COLUMN,TILT TYPE TILT STRG COL(N33)
PF4WHEEL,16X7(ALUMINUM) AL WHL(PF4)
QGBTIRE ALL P245/75R16 WOL R/PE ST TL AT 109S TIRE(QGB)
R8WCONTROL - SALES ITEM NO. 72
R9LCONTROL - SALES ITEM NO. 87
SLLSOLD ORDERS SOLD ORDER(SLL)
TFESALES INCENTIVE - COMMITMENT PLUS
NRWhiteKnight
NRWhiteKnight
Kentucky
Thanks, Sun. Appreciate the confirmation. :)
CPI? Is that the type of fuel injection system it has? I'm an old school carb guy, with minor knowledge of fuel injection (very minor,lol).
jmc86
Sunlit do u have some sorta connection some where or do u have one of them life time memberships to carfax?
SunlitComet
OBS Jedi-Do Good
central point injection. all the injectors were housed in in a single body with lines to each cylinder with a poppet valve at each end. each cylinder got its own down the manifold runners. unfortunately the poppets mixed with low quality gas proved problematic. they have since redesigned the unit to work so much better. if you have the original injector spider in there do your self a favor if it has not been already and replace it along with your lower manifold to block gasket. if you had to state what were the major issues with the engine build it would be those along with maybe the distributor gear. not biggies really butt that covers how most of the engine failures happen. the new spider from amazon
delphi fj10566 http://www.amazon.com/Delphi-FJ10566-Fuel-Injector/dp/B000TYLIFS/
and gasket kit http://www.amazon.com/Fel-Pro-MS98000T-Manifold-Gasket-Set/dp/B000CH0C0Y
and bolt kit
http://www.amazon.com/dp/B0039SOMUE/?tag=k--20
will go a long way for the truck.
---------- Post added at 01:32 PM ---------- Previous post was at 01:31 PM ----------
sorry no carfax connections.
saif najd
and bolt kit
Thats a cool looking thing! But I have never seen such injection system like this what I know is the LS1 injection system and other similar systems
Could you please tell us more and how it could help the vortex engine? I have a 98 tahoe how or why should I fit this?
inthechateau
Maryland
Sunlit knows what he is talking about on the SFI. CFI was OEm and if you had any issues with O2 sensors, lousey performance or MPG then the CFI is the culprit. Did the conversion to SFI when I changed engines on my 96 and what a difference. Those are good prices in that link too.
Donnie Yukonie
Yates Caretaker
what does the speedo go to on it? 130mph was the easiest way to see if it was a police package..
x2 on this and 9/10 the police packages were "mildly equipped with creature comfort options such as heated seats and leather and the only 2 that I seen did not even have carpet in them but vynle flooring
SunlitComet
OBS Jedi-Do Good
Thats a cool looking thing! But . Addahave never seen such injection system like this what I know is the LS1 injection system and other similar systems
Verry dlimited access for me right now here but i should add te upgrade is a drop in replacement if there was confusion on that.
MeanSlickCaddi
