Brembo Brake Upgrade - Pad Part Numbers?
cjlewis
I needed new brakes as part of the 90K service on my 2023 Yukon and decided to upgrade to the Brembo brake package.
I know some owners have mentioned issues with the stock brakes and rotors, but personally I never experienced any problems with mine. That said, I also don’t tow, so others who do may have a different experience.
After the upgrade, I can say I absolutely love the Brembo’s. The pedal feel and responsiveness are noticeably improved — braking feels more confident and refined overall.
I’d definitely recommend them.
For anyone considering the upgrade, I purchased the kit online through the GMC website while they were offering a 25% discount code. You can also add dealer installation at checkout, and the parts shipped directly to the dealer for install, which made the process really easy.
ReaperHWK
great. Also considering on my 2026.
I read that you may lose the brake pad wear sensors. Is this true? Can you still see this on your displays?
randeez
south florida
the brembos need a specific wear pad sensor, as it sits deeper in the caliper than the 4pistons - but it plugs into the same connector on the truck
but i was unable to reset pad % on the UI, i heard the dealer service needed if swapping just disables the wear pad sensors?
ive noticed i am unable to reset some other monitors (air filter life, fuel filter) if its not below 50% though so i may try again when it gets below there (sitting at like 54% now)
jpurdie
