[SOLVED] Major work done, now thick white smoke
West 1
When you try and start it, if the engine turns over hard or even stops turning. STOP. That would indicate fluid in a cylinder. If you try to start against fluid in the cylinder it will hydro lock and maybe break a piston or bend a connecting rod.
If it spins normally certainly start it and hope the smoke clears in a minute or two.
T
tombguard4
Thanks, guys! You helped reaffirm my thoughts that it was just moisture and cleaning materials burning off. I had the courage to go out and start her again. About 20 minutes later, she is running clear. No smoke! The engine sounded fine, no leaks on the ground, and fluids are full and clear. On Saturday, I will put the wheels back on her and take her for a spin. I am pretty sure she will be running better than before.
Good to hear!
If yours were mine, I would be looking at the upstream and downstream O2 sensors while out on that drive to make sure the cats didn't get fouled up.
Remember, upstream sensors move up and down quite a bit, downstream sensors are much more steady, unless there's a problem with the cat. If it starts showing data like an upstream sensor, it's catalyst time.
LsHart
Senior Member
Coolant line to throttle body
LsHart
Senior Member
Going back. When u say white smoke on start up. What's the temperature where ur located? And was it super cloudy? Like everywhere as it ran?
