Oem Chrome trim door handles
Cha0s13
Anyone have the part # for the outer oem chrome trim w/ passive entry door handles for a silver ice meatallic tahoe? I'd like to add a set of the oem ones on my 2019 Lt. Dealer is having trouble trying to find the part #s ;(
a lot of times the oem part number is just one digital off at the end for variables, so look up the part number for your handles then do a search for the same part but change up the last digit each time, otherwise if you see one on the lot and it has the handles you want just write down the vin number and take it the parts department.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
PART # FOR THE FRONT DOORS
GM#13585377 $145.92 EACH
HANDLE KIT, FRT S/D O/S (PAINT TO MATCH) (INCLS ANTENNA) (W/CHROME INSERT) (ATH,X88,Z88,Y91) 2015-2019
PART # FOR REAR DOORS
GM#13585374
HANDLE KIT, RR S/D O/S (PAINT TO MATCH) (W/PAINT TO MATCH INSERT)(ATH,X88,Z88,Y91) 2015 - 2020
NOT SURE ON THE INFO ON THE REAR HANDLE KIT, I GOOGLED THE PART# AND SHOWS CHROME HANDLE W/ PAINT INSERT
SAME FOR THE FRONT GOOGLED # SHOWS CHROME HANDLE W/ PAINT INSERT
Cha0s13
Cha0s13
Thanks for the part #. So these would have to be be painted to match?
rick3645
