BlackBear tune, still not right
PunisherZ71
i got a tune, z71 Tahoe 5.3 thing is in great shape. It feels like it has no power what so ever. I told bb about it they said change Maf so I did, it still isn't right
NathanJax
Vacation Nathan
Jax, Fl
What year? Any other mods? Who at BB told you that? After you swapped it, did you let them know it didn't fix it? Did they tell you to go away and not bother them?
Are you saying this to get help on this issue, or just to bash BlackBear?
I'm sure Justin and Jenna are able to try and help... @JennaBear
JennaBear
Resident Ninja
San Diego, CA
Nathan hit it on the head. Have you let the guys know? Sounds like there is something else going on, they are more than happy to help, if you let them know what your issues are.
Sent from my fone.
AllStock
Mass
Yeah def need to communicate back and forth with them. ive been bac and forth tweaking small things here and there witu my tune from them
Love their support and willingness to keep going back and forth
P
PunisherZ71
I did tell them that it still was not right after 2 weeks still no answer, I'm will not nor I want to bash them I would like some help with the problem tho.
JennaBear
Resident Ninja
San Diego, CA
That doesn't sound right, what email are you sending from?
Shorties and a muffler won't net you any performance gains...but you should feel a difference with a tune.
JennaBear
Resident Ninja
San Diego, CA
Major problem areas to look into:
-dirty MAF
-faulty MAF
-dirty throttle body
-poor fuel
-bad plugs
Also, did you have a traditional, scan cable or AutoCal? If you have an AutoCal, send in new datalogs for the guys to review, they can usually recommend some fixes.
If you have a traditional tune, this is one of the biggest reasons I highly recommend the scan cable or AutoCal; there is no way to see what exactly is going on with the vehicle. It is a best guess with the information you give. The customer could have horrible gas, or a cracked plug, or dirty MAF/throttle body; there is no way to diagnose.
ccapehartusarmyINF.(ret)
Gilbert AZ
okay usually when u buy something thats expensive and it dont work you dont send them an email and wait around two weeks for a reply
you get someone on the dam phone to help you figure it out they still got those dont they telephones?
P
PunisherZ71
I have a new Maf I cleaned the throttle body and have just replaced plugs, I think they need to just look over my tune. When I first sent it to them I had just put in a 6.0 not long it acted up, heads were bad so I replaced it with factory 5.3 I think they are still tuning it thinking I have the 6.0 still in it.
JennaBear
Resident Ninja
San Diego, CA
Do you have a traditional or scan cable? Sounds like you have a traditional... There is not much for them to "look over" unless you did a scan cable or AutoCal tune. There could be a mechanical issue or nuance to your vehicle that they have no idea about.
Did you let them know you switched engines?
Sent from my fone.
P
PunisherZ71
Traditional tune, I sent it back in and told them it's for a 5.3 not 6.0 now
P
PunisherZ71
Got it, thanks didn't see that email I guess, thanks for the help. I was just thinking maybe theyou didn't get that the 5.3 was back in the truck, so they tuned it for that instead of the 6.0
JennaBear
Resident Ninja
San Diego, CA
It was tuned for the 5.3. You may consider upgrading to the scan cable, there could have been an issue with the reinstall. Can't tell you how many times they diagnosed an install issue for a customer via data logs.
Brian Wilson
I can attest to that. They helped me solve a problem thru email that 3 dealers couldn't even find with their fancy gm tech 2. And it only took sending a 20 minute data log and 1 email. Justin nailed it right on the head and 10$ later, my car was fixed.
Chip18
Dayton NV
you get someone on the dam phone to help you figure it out they still got those don't they telephones?
The phone call .. is great for "hand holding" as it were but a phone call can't get you answers directly. Tuners need to see the "Data Logs" in order to help with a tune or problem solving.
I'm sure a they'd be happy to explain how things need to be done in a "phone call" but if your not driving to the shop ... then you'll still need to send in the data logs. . :)
DPGDirk
I'll chime in here...reluctantly.
I drove to TX and had Justin tune my Yukon.
Added headers and exhaust and purchased an Autocal.
Tried multiple times to get the data, but the instructions were vague. I was asked if I read the instructions on the website, which I had.
Sent multiple e-mails and finally got a step-by-step e-mail on how to log the data.
That info I got at that point was not on the website.
Call me crazy, but if there is a step-by-step method, I don't want to guess what it is. The instructions on the website did not provide those details.
Finally got the data after the 3rd or 4th try and sent it in.
Got the updated file back and tried to load it on the truck.
Same thing. Multiple steps and screens that were definitely not in the instructions.
More e-mails sent. Asked several times if someone could help me via phone. No luck there.
The entire loading process only takes a few minutes.
I was disappointed that I couldn't get someone to help my dumb@$$ with a 5 minute phone call after all of the e-mails that didn't get it done.
I had multiple screens that I did not know what to do with. I didn't know whether to hit the back arrow or the OK button or what.
Folks, if it is a step, you should have that step listed in an instruction somewhere. Vague generalities are just that. This really burns my behind.
At the end of the day, I don't know if it loaded correctly or not. I know I had an error code at the end and assume it's not right.
This all happened MONTHS ago. I gave up. A good chunk of money spent on an Autocal that I haven't been able to get right.
I was impressed with Justin's work in TX. Far less impressed afterwards. Been keeping my mouth shut, but decided to speak up.
Not trying to intentionally "bash" BBP, but if my honest experience is taken as such, I guess I can't help that.
I think BBP could and should have better detailed instructions that actually take you through the process, so no guesswork is required.
Maybe even an instruction video.
ivin74
05 NBS Nali
Htown, Texas
I had a similar experience with another online tuner (not throwing him under the bus) when I got my Silverado SS tuned. After that tune I refuse to anyone unless they are local, that way if I run into a problem I can easily drive over to their shop and get my shit fix. On this particular tune I ended up paying for it twice one for the online tune and the second time for a local tuner to make the adjustments needed to get my truck to running right..
dubyagee01
My experience with BBP was flawless a few years ago. Mine was a cable tune/ECM swap with a crank relearn. Instructions covered everything I ran into and Emails were quickly responded to. There are glitches with any business though.
Conedaddy
