Tire sensors issues
Jedi-GT
Hello everyone
My 2004 tahoe was missing the tire sensors. Went ahead and installed the sensors and sync/programmed them to the car.
Got the tire pressure to 32PSi as recommended and I went off on a drive ... The "check tire sensor" message pop up.
Plugged in the code reader and it showed the reading of the sensors at 16psi
I'm not sure why the sensors reading the tires to be 16psi because that means it's flat tire. .
Please advise
AppocAlexx
Darth Appocalexx
Abilene TX
Kind of weird them reading 16 psi with out you noticing the tire being flat. They would for sure look close to flat. Also 32 is a bit low for any truck. I would bump it up to 35 or even 40 and see if that turns the light off. Also I have heard that getting the after market sensors sometimes have crazy readings and issues. Not sure on what sensors you got aftermarket or dealer item. Good luck.
treehan77
TYF Fiend
Crestview, FL
my truck states 35 psi inside the door, as i'm sure all NBS probably do...i just put in the Dorman sensors from amazon and they are dead accurate. didn't know the code reader would read tire psi, ill have to try that.
Jedi-GT
Jedi-GT
16psi is definitely low and almost flat. The sticker on the side door shows 32psi. But, I also thought its a bit low so I bumped it up to 35psi just to see if I get any different readings. They are indeed aftermarket sensors.
It sucks that I think I need to go pay to remove them and take it back to the dealer. which mean I need to pay to install them and reprogram them. Sigh
treehan77
TYF Fiend
Crestview, FL
You don't need to pay to reprogram them you can do that yourself. Most tire places will install the sensors as well, probably cheaper than the dealer.
Jedi-GT
Jedi-GT
I didn't go to the dealer to do it. Tire shops don't have the programmer. I paid about 30 bucks at a store but I think he might be kind enough to do it for me again. I go there for my 2dr Yukon and my 04 Tahoe.
David Paul
Central NJ
How are you guys getting the actual psi readings? I've never seen that on my 04.
AppocAlexx
Darth Appocalexx
Abilene TX
Code readers will not read them but for the high dollar computers they should read the PSI, you just have to find the right settings. Also I'm talking about the $10K computers like my padre has. His does all sorts of stuff.
Your truck will not read them, it will just set of a light saying its too low. As stated above some computers will be able to read the actual PSI.
AppocAlexx
Darth Appocalexx
Abilene TX
You don't need a programmer just do the procedure in the manual
Not positive on the older models 06 and down but 07 + you do need a programmer. Amazon sells them for like $80ish and I will prolly be ordering one soon. All the shops around my place are going to make me set up an appointment and then pay for something that you can teach a 5 year old to do. If any of you are around a Discount Tire or Big O's (discount tire bought them out) then they should do it for free. Takes literally 2 minutes as long as your sensor is not broken.
treehan77
TYF Fiend
Crestview, FL
Do you mean with a code reader or the DIC? Cause my 05 shows each tire pressure in the DIC. are you saying 2004 model year doesn't do this or you can't do it on your code reader? Cause I thought 03+ do this with the DIC. but code reader probably not, that's why I was surprised previous post said his code reader shows it, I have yet to try mine to see. What code reader and app are you using Jedi-GT? Did you test the 16 psi against a real physical tire gauge?
AppocAlexx
Darth Appocalexx
Abilene TX
Never owned a chevy and did not know that they showed psi in DIC, that's cool, especially that old of a year model. I know that the newer fords also do in the DICs but you have to have the higher end models as well.
David Paul
Central NJ
My 04's owners manual is very ambiguous about this, saying it may show a reading or just throw a warning light when low. I've only seen the warning light. For you guys that are getting the readings in the DIC, how does it come up?
Thanks
treehan77
TYF Fiend
Crestview, FL
Press the steering wheel button until it says TIRE PRESSURES the. The other button (return?) cycles brought each tire
Jedi-GT
Jedi-GT
My 04 tahoe is not full options but it is a Z71 ... no steering buttons.
Mine only throws the code "check tire sensors" which means I need to plug in a tech 2 it any code reader.
Plugging in the code reader showed that the sensors reads 16psi in each tire. Which made me know it's the sensors.
Sent from my SM-G900F using Tapatalk
Jedi-GT
Jedi-GT
I went and picked up delco sensors to replace the after market darn sensors. Took them to the tire shop to replace them. But, it wasn't that easy, the darn sensors did not include the bolt nuts to hold them in place. Yes ... they come separately ... I had to go to the shop and pick them up again. I had to wait 3 days to get them in.
Went back to the the tire ship AGAIN and got them switched and then reprogrammed them.
No code ... as good as new ...
My loss was few bucks to get them on ... off ... on again.
I got a little discount though.
I usually go with delco but that time was a one off the usual for me.
Always go with delco friends
JamesinAbilene
