05 Yukon/New guy
S
Skipper50
Galveston county, Texas
SE Texas, '05 Yukon XLT 1500
Replaced rear seal and oil pan to stop leakage. Tranny was dropped for this.
Following reassembly the transmission will not shift.
Found and replaced failed brakelight switch.
Still not shift.
Fluid levels are good.
Can't find anything impeding shifting.
I'm thinking the TCM lost it's mind.
Suggestions?
Still not shift.
Suggestions?
If the torque converter moved and is not clicked in all the way then it has to come out. Let's ask Nick: @NickTransmissions
NickTransmissions
Sin City
The transmission bench
Still not shift.
Suggestions?
It won't upshift from first gear? If so, check to make sure your vehicle speed sensor is plugged in and wire not cut/frayed.
rockola1971
Indiana (formerly IL)
Still not shift.
Suggestions?
Need more info about this "tranny will not shift"? What do you mean? Wont mechanically shift into (D) or goes into gear but wont shift past 1st gear? Does manual 1 or 2 work? Did you get your shift cable properly attached to tranny and not get the adjustment out of wack at its adjuster?
S
Skipper50
Mechanically appears to shift but the transmission doesn't engage in any gear. Will check speed sensor and shift cable.
scottd
