Please in the name of all that is right, can we get rid of the triple honk already?
Shadow17
Shadow17
Just to add to this...
I'm away from home on a business trip and get a nail in my tire. I do a giggle search for tire shops and pick a nationally recognized chain. I go there and leave them the keys and wait for my vehicle.
The tech pulls my Tahoe into the bay (I'm watching like a hawk--yeah, im that guy) and, guess what? Leaves the keys in the vehicle (as is customary). Know what happens next?
Can you guess?
Wait for it...
Yep, in seven bays about half the mechanics crap themselves as my Tahoe goes HON-HONK--HONK!!!!
Sad but true... Wish it were a separate speaker/driver/piezoelectric whatever and more of a pleasant chime!!
Just had to share.
The thing that gets me is you never hear a BMW, Mercedes, Audi, Jaguar, Range Rover...do this.
To me, it's just cheap sounding and annoying.
Kpwweb
Maybe they don't have keyless entry?
Just kidding! Maybe it's a clientele difference? Gm and Ford think we're stupid...?
But I agree 100%. On a $60k+ vehicle, we need a little more class! Or a tranquilizer for our nerves!
Denada
Mine doesn't triple honk if the keys are in your pocket and you get out. It does chime once you get back in though (key not detected). I have passive locking off, have any of you checked if this could be the culprit? The options are: Off, On with Horn Chirp, or On.
Not sure if there are any Arduino or Raspberry Pi enthusiasts on this board but pretty sure you could build something that sits between the horn and the horn power leads. You could easily write code to monitor the power levels and pass everything through EXCEPT when it senses a series of 3 quick spikes. I mean if it is something that really annoys a lot of people in this thread I could explore creating the device. Does it annoy you enough to pay $100 to get rid of the feature?
Kpwweb
I have passive locking turned off as well.
You could program a Pi to block the signal--or even more special use it as a trigger and pass it through as a chime to a small waterproof speaker located somewhere up front. Then you would have something!
Shadow17
Shadow17
I had the passive locking off on mine originally. I believe it is off from factory.
I turned it on because I like having it lock automatically as I walk away.
Weird that yours doesn't triple honk Denada. I have turned every feature on and off, and there is no way to eliminate it on my truck.
Demer
Eagle, ID
My 2016 Yukon Xl Denali acts the same way as Denada's.
I can get in, start the car with the push button, get out with the engine still running, walk away, and no triple honk.
The only time I get a triple honk is if I turn off the car and exit the vehicle with the key fob still inside.
NYisles1
Same here with '16 suburban z71.
DWTahoe
Colorado
Are you closing the door after you get out with the fob in your pocket? I'm just checking since you didn't mention it specific. If I leave the door open it doesn't triple honk until the door is closed and the fob is outside.
I guess this could also be a difference between the '15s and '16s....
Sorry i didn't figure out how to quote...I was asking "Demer" and "NYisles"
Demer
Eagle, ID
DWTahoe, yes, the doors can be closed after I exit the vehicle with the engine running and I do not get the triple honk.
NYisles1
Same here.
We have two other GM vehicles that work the same way as well. Did you try restoring factory default settings? At least that would rule out a setting change.
rattmobbins
Can you guess?
Wait for it...
Just had to share.
This had me laughing so hard! Thanks for sharing!!!
WYO-HD
Without a doubt I love my Yukon Denali.
But if anyone reading this has any pull with GM, would they please put a bug in someone's ear to get rid of the triple honk when exiting the truck with it running? Every other feature can be turned on or off.
It is a shame an $80K SUV needs to sound like a '90's Ford Explorer locking the doors' every time I exit it with the engine running.
The informative horn honk is way underclass for such a nice vehicle.
Any luck finding a fix for this? Mine does the same...I agree, it is annoying. My wife's XTS does the exact opposite, honks at you if you leave the fob in the vehicle.
Cheers,
Shadow17
Shadow17
Nope. I could not find a way to turn it off.
For now I either leave the drivers door hang open when I jump out or leave the keys on the center console.
It's either that or turn it off every single time I need to jump out of the truck.
Tinker
I had a 15 Yukon XL SLT - no option to turn it off. I have a '16 Yukon XL SLT now and it has the options in the menu to turn it off. Perhaps the 15's can have the system updated to the same on the 16's to enable this option... not sure. It is very nice to not have this obnoxious honking now.
Another note - that the system is MUCH faster on the 16 than the 15. The 15 was always slow and seemed to be under powered. The 16 is MUCH faster.
Shawn Cranford
My 2017 Yukon XL Denali and my wife's 2017 Escalade both do this. My 2016 Suburban LTZ did not. It's horribly annoying and startles me every single time.
Tyler424
Boston
Okay so i have not read through all of these posts, so sorry if this has been stated previously. But there IS a way to turn off the "Remote Left in Vehicle (Triple Chime)" and "Engine Still Running"
With the vehicle running go to settings --> Vehicle --> Remote Lock, Unlock, Start --> Remote Left in Vehicle Alert (at the bottom) --> Turn off.
This will turn off both alarm chimes. Hope this helps and works for everyone. I have only tried this on a Tahoe but it should be available to everyone with newer infotainment systems across all brands.
chicagofan00
Arizona
^I'll have to check if my 2015i has this option and if it works. I've explored the menus pretty well looking for the solution but I suppose it's worth yet another try to get rid of that annoyance.
Kenny D
Crosby, Tx
No offense bud, but you truly don't know what we are talking about. Perhaps your truck is different. There is a triple honk that does alert you if the key is left inside the truck after it is turned off and you step out. That can be turned off and mine is.
My truck, and others, honk if you step out of the truck and close the door while it is running with the key in your pocket.
And conversely, if you start the vehicle and exit it with the key fob inside the truck it will not honk. How would it exactly know you exited the vehicle? Just because you opened the door? The truck is still running and the key is inside...
Just an observation, I probably can tell you exited by the seat sensor. It picks up weight, like the passenger side airbag in the NNBS tahoes.
Drewphil
