Let's see some pics of some lifted and leveled
vinnyray
Lancaster, PA
It's 1/4" higher in the rear but appears to sag on level ground. I didn't want to do a lift/level because I'd need taller tires.
Jonah52
Senor ******
Cleveland
Yeah it's the way everything sits. My truck with the 2.5-1.5 sits higher in the rear bit appears to sag. It's less noticeable without the running boards
jbjohnson
Colorado springs
Put on leveling kit and rims/ tires today as well as removed front valance. Here is a before be after.
jbjohnson
Colorado springs
Nice. What kit and tire size? Looks like you cut the valance tabs off?
Thanks, they are 285/65/18 Toyo open country at2. The leveling kit is a 2.5 from just lift kits on Amazon, no rear lift, sits perfect and I took a drimel to the valance tabs. Debating on removing the sidestep
Skatejosh369
What would most of you say is the perfect tire size for a RC 2" leveling kit with factory 20" LTZ wheels? Just installed the kit yesterday and took running boards off. Have been heavily contemplating 275/60/20 bfg k02s, but another part of me really wants to run a 33x12.5 in a more aggressive tire. Opinions?
Skatejosh369
That's more of what I'm going with just due to being nearly 300 a set cheaper. Bfg k02s your recommendation?
Skatejosh369
That's 2" rc kit. Removing door trim next week after it getss out of paint, and new headlights ordered.
YukonAZ
The other thing about 275/60s is that they are a common size so chances are most known tire shops will have a tire in stock!
vinnyray
Lancaster, PA
33x12.5 would be tight and require trimming. I'm running 305/50s (12x32) and rub slightly on the sway bar. Go 275/60 if you want taller or 305/50 for wider.
jpurdie
