Esky taillights
NowZoomer
Right I'm basing it off of Escalade lights or any modern day LED is definitely brighter than this
toi
Some random car in front of me today, sun coming directly from the left side, u can clearly see this guy has its brakes on
toi
And this from my suburban with smoked lenses,10 mins after the other cars pics, this time around the sun is kinda around 7:30 position coming on to the back.
Like i have mentioned before,the suburban models have the blinkers come on as brake lights as well
DenaliBQ
Thanks for the video but are your tail lights as bright as the third brake light ? Because they should be
NowZoomer
I hope the ebay seller fixes this for you all
Coming from the insurance pov, if someone rear ends you, and his adjuster notices you've changed your brake lights to these - which are definitely dim - be prepared for a fight
toi
Wanted to share a quick video of my lights on a full sunny day. I didn't see a problem with mine compare to the picture you posted.
to be honest with you , your side brake lights are not noticeable at all by looking at this video.
that being said mine are pretty much the same probably.
hmmmmmmmm
Edit: found this vid online,not as sunny day but fast forward to 50th second and you can see him apply brakes and tail lights are clearly visible,ours definately are not
Richystahoe
Hanover park, IL
Defkhan those look great, and you have the amber blinkers too! As I was driving today and the wifey following behind me, she informed me that when turning the long led blinks along with the short one. Didn't think it did, cause when in park it doesnt so guess only in drive it does.
toi
my 16 suburban still doesnt have the correct working lights.
the seller sent some new resistors which had different plugs.
when headlights are off , i put the turn signal and the other side also starts blinking faintly.
what a mess man.
i am kind of getting over this BS
DenaliBQ
anyone have any luck with the vland lights and does anyone have the actual part numbers off the oem escalade lights everything i've seen has been different numbers ?
dcp17420
Any updates on the functions and brightness of the Vland tail lights ?
bourgeois
I spoke to vland about 1 month ago and he stated the tail lights were passed by the DOTD and there were not to worried about not being bright
NowZoomer
I would not bet on this being truthful unless you see the actual certification
NowZoomer
He sent me one, but I did not bother to look at
Ok, I don't have anything to gain by being wrong, but I just find it hard to believe that a Asian vendor would go through the expense and trouble to get US certified. It is far from cheap.
DenaliBQ
anyone have any luck with these lights as far as brightness or the oem escalade lights
bourgeois
I have a after market HID kit and esky tail lights on my 15' Tahoe. I noticed yesterday while driving when I press my brakes the LED strip lights up and stays lite until I release my brakes. When I put my turn signal on, the LED strip blinks with the turn signal.
It only happens when the headlights are off. When I turn my headlights on or the parking lights, this does not happen.
CAN SOMEONE ELSE, OR ALL PEOPLE WITH THESE CHECK AND SEE IF THIS HAPPENS TO THEIR VEHICLE? THANKS IN ADVANCE
mbp1979
North Little Rock
Does anyone know if the oem escalade taillights will work on a 2015 tahoe. I know they will stick out on the bottom I'm mainly concerned about the wiring?
toi
they work but you will need resistors
briannorris
