Your luck with code scanners
rook
Any recommendations for code scanners? Got a 2007 Denali. I want to check, log, clear codes.
Erik G
Houstone Town
I've never had an issue with even the cheapies from autozone. My superchips tuner does it all as well
Even the cheap autozone reader will tell you if all systems are ready, which sensors still aren't turned on after clearing codes, etc
drakon543
Some of the innova scanners have higher functions similar to much more costly scanners. I've used a couple they aren't a snap on solus or anything but they are nice. If you just want to read and clear codes the actron pocket scanner works great but falls short on higher end cars and unless you get the more expensive version it also can't read the history or display live data.
Korbin_A
