Installed 6000k VLED LED Fogs
BEEMDUB
PIMP DADDY FLEX
Michigan
Looking to join the recent led fog bandwagon, I bought some 6k fogs from Vled.. Still think it would of been nice for GMC to through in HID's and led fogs with these <50k trucks..but whatever..heres pics!
cship
do you have the link to the ones you bought?
lweisenb
How is the performance, do they actually work well as a fog lamp? The beam on the headlight starts fairly far out because of how high they are, does this bulb do a good job illuminating right in front and to the sides of the vehicle?
AIR-RUN
I can't find my size still... PWY26W ..??
Camstyn
Just curious, what's the difference between the P13W and 5202 bulbs? Are they interchangeable? Everywhere I look it shows that the Yukon takes 5202 fog's.
WillieFlo
Houston, Tx
BeemDub,
How is performance on the road? More lumens or less than the halogens? I don't want to sacrifice actual night time visibility for aesthetics.
BEEMDUB
BEEMDUB
PIMP DADDY FLEX
Michigan
BeemDub,
They're definitely brighter, and look way better..pretty much no cons
barrett20au
I installed the 5000k VLED fog lights last wknd with 5000k HIDs, but the temps look different(hid vs led). The HIDs appear just a touch bluer than the truer white led's. Thinking of replacing the fogs with the 6000k bulbs to try to match closer.
Nabbz
How are you guys installing these fog bulbs? I was looking under the front bumper and the corners are protected by some huge bracing, which seems to be blocking reasonable access. Maybe it is easier if the car is lifted? Of course it would help if I was 30 years younger!
Demer
Eagle, ID
I just installed these bulbs about 10 minutes ago in my garage. No lift was needed. I just crawled under the under front of the car with a little flashlight and was able to reach up in there. The entire process took just a few minutes.
X-ray Nerd
