TOYSTRY
how does the panel above the glovebox come off does it just pop out no screws ?
Glovebox doesn't come off per say......there are a few items that need unscrewed (torx) and you also need to disconnect the tension wire latch on the right side that controls it from slamming open when you open your glovebox. Just get in there with a flash light, it will all make sense. With that, there is really no point in removing the glovebox unless you're trying to install something inside it.
jackedupZ71
just got done installing the Airaid MIT on my wifes tahoe, took a whole 10 minutes. next is tune and exhaust [emoji2]
WYO-HD
What did you do to your GMT K2UC/G Tahoe/Yukon Today?
This....:)
Ben
PCB, FL
First oversized tires I've seen on the stock ltz 22's looks good
WillieFlo
Houston, Tx
I added the Suntek PPF, Blacked out the window trim and fog light bezels, and smoked the tails/3rd brake lights.
jdpber
GOLD MEMBER
The America
is the rear axel centered int he wheel well? or is it just the angle of the picture?
LGSONE
Very nice. You have unique ride and it looks mean and classy. Mostly mean... ;)
Have you thought about trimming the front lower valance. In my Silverado days this was a popular mod for the lifted trucks.
LGSONE
WillieFlo
Houston, Tx
LGSONE
LGSONE, I've thought about it, but I'm wondering how it would affect 3 things, 1) airflow into the engine bay that affects cooling; 2) aerodynamics which affect MPG's; 3) how it would look if I did. Don't want to chance cheapening the look by chopping it and regretting.
Don't need to do it for off-roading clearance because I haul this for hunting and my serious playing off the pavement.....
Thanks for the complement!
ktpinnacle
So Cal
"It's like, how much more black could this be? And the answer is none. None more black."
Nigel Tufnel, Spinal Tap
Denada
Looks great! If you aren't blacking out the grill (body match might be an option too) then maybe just Dip the front and back GMC's?
mikeydread
The ride is a bit more firm with 24's, but not uncomfortable. One thing i have noticed though is that it has started buffeting a small amount at highway speeds. It seems intermittent, but i'll have to keep an eye on it. It buffeted previously (when i first purchased it) with the factory 20" wheels until the dealer road force balanced/replaced the factory tires... So I may end up having the 24's rebalanced/road force balance if it starts to bug me.
I'm running the Dub Skillz in 24x10, and Nitto NT420S tires in 305/35/24. Theres some minor rubbing at full crank, but not enough to bother me. If you want to avoid rubbing altogether, i'd go for the 295/40/24 tires. Other than that it's good to go.
mikeydread
Thanks for the reply Flynnst0ne, i just order some Giovanna Bogota 24x10, i will post some pics when i get them. i will like to go with a 305/40/24 because NYC has a lot of pot holes. the wheels are on back order so i have one month to make up my mind on what size tire to go with. Thanks Flynnst0ne your info help me a lot.
Merch619
