Wood & Silver Trim Interior Removal (Doors, Dash, Center Console, Steering Wheel)
TOYSTRY
So let me start out by saying this isn't for someone who's scared of ripping apart your interior and putting it back together. Let me also state that this isn't a quick half-day job. It took me roughly 2-4 hrs to take apart the interior and butane remove the pieces that are melted together (yes, you'll need to take a butane torch to your dash if you want to wrap it the right way. In short, my Tahoe interior is literally in pieces all over my garage with a ton of screws everywhere inside the interior.
Certain parts of this removal process requires you to use some tough-love (muscle) to disassemble the vehicle. I only needed a few tools, but some aren't common household tools so I provided a list below with hyperlinks if you need to purchase these items:
- Standard Socket set (1/4th)
- Phillips Screwdriver
- Security Torx (Star) Screw set (T15/T20)
- Auto Trim Upholstery Removal set
- Mini-Pencil Butane Torch
Of note, I didn't take pics of every single step. As a matter of fact, I didn't take any pics of the dash disassembly because it's too complicated to be honest. Some of this stuff below is common sense, so if you lack that, don't try this at home. Take it to a custom shop and let them disassemble your vehicle.....again, this isn't for someone who is afraid to tear apart your car.
Step 1:
Remove the screws from the door. You have (1) screw behind the door handle (hidden behind a cosmetic plastic cover), (2) screws under the arm rest (hidden behind a cosmetic plastic cover), and (2) screws (exposed) on the bottom of the door.
Once you remove the screws, use the auto trim kit to pry away the door panel from the door. Typically once you get a bottom corner up, you can use your hands to pull away the door but realize you may break some of the plastic tabs off (they are cheap, you can buy new ones so don't sweat it). Once you get the sides/bottom of the door pulled away from the panel you're gonna have to tackle the top. What I found that works best is to start at the front of the door and lift/wiggle until it comes up then start working towards the back of the door by the locking mechanism. You're gonna need to use some muscle here, so don't be scared.....the entire door comes off in one piece (including the felt glass protector so be careful as that is connected).
Of note, I always had a damn clip get stuck in the door (same spot both sides). They are easy to remove and reinstall, but worth pointing out for reassembly.
Step 2:
Disconnect door handle wire and electric window plugs (and plastic plug holding the harness to the door). Pretty self-explanatory on this (assuming you've disconnected an automotive switch before). Push the plastic clip down, pull harness/wire away....pretty simple, don't nuke it. No pics btw (I only have one hand to hold the door and remove the harnesses).
Step 3:
Remove the wood trim. Pretty easy once I figured it out. First you have to tear away the white insulation for the door panel. There are 2-4 glued tabs that you'll have to rip away to gain access. Don't fret, you can use some hot glue, gorilla glue or something later to stick it back to the door if you concerned (I'm not). There are 4 screws (I repeat), there are 4 screws and only 4 screws to remove.
There are 4 silver screws (I repeat), there are 4 screws and only 4 screws to remove (the screws are only touching the black panel, don't remove the two screws in that white piece of plastic you see). Two screws are by the backside of the door panel and two towards the front side (where the front of the wood trim panel ends below the window module).
Unfortunately those 4 screws aren't the only thing holding the trim piece on there. There are also 4 push tabs (find where the tension is and pry gently put firm enough for them to pop free).
Here is how they match up for reference on where to pry for the push tabs.
T
TOYSTRY
Step 4:
Remove the back doors. Repeat steps 1 & 2 above. The only difference is that there is only one screw on the bottom of the back door vice two screws.
Step 5:
Remove the wood trim. Pretty easy once I figured it out. First you have to tear away the white insulation for the door panel. There are 2-4 glued tabs that you'll have to rip away to gain access. Don't fret, you can use some hot glue, gorilla glue or something later to stick it back to the door if you concerned (I'm not). There is (1) screw (I repeat), there is (1) screw and only (1) screw to remove and one push tab. The rear panel is only has (1 screw and 1 push tab to remove).
Unfortunately that (1) screw and (1) push tab aren't the only thing holding the trim piece on there. There are also 2 more push tabs (find where the tension is and pry gently put firm enough for them to pop free).
Step 6:
Enjoy.....your door panel trim is now removed.
T
TOYSTRY
Center console removal.
Step 1:
Remove side panels by floor. You’re gonna need to use some strength to remove these because they are held in place by push pins only I believe.
Step 2:
Open center console. On the leading edge of the console, you’re going to lift up and towards the stereo system to remove the center console.
It’s held in place near the stereo with two push pins.
Step 3:
I choose to leave all the harnesses connected as I could get to the (1) screw per side that you need to undo. Once you remove the (1) Phillips head screw, there wood grain has (3) push pins per side that need to be popped out.
Step 4:
Enjoy….your wood trim is removed.
T
TOYSTRY
Steering Wheel Control Removal:
Step 1:
Remove plastic pieces (paddle shifter spot) pulling applying some pressure and pulling them out. They have a wiring harness attached so don't rip it out. Push the plastic piece with harness off to the side and grab a T20 security torx tip and gently remove it (I was very nervous mine was going to strip as it was in there so tight....remember righty tighty, lefty loosey).
Once you get loosen the T20 (it doesn't come out btw, it just loosens enough to release the steering wheel controls) you're gonna need to pry out (it's a pain in the ass) the steering wheel controls (the trim is connected to the controls, they come out as one piece).
Of note, the bottom of the steering wheel plastic trim has a piece that pushes down) so you'll have to gently pry that piece up first before you can pull the whole trim piece out. This was a very time consuming removal, probably close to 30-45 mins just to remove these two small pieces as I didn't want to snap them (they are $70 each I believe). You have to use a lot of muscle to pull them from underneath the airbag cover so take your time and be careful.
Once you remove the trim/controls, there are 3 screws that need to come out to separate the trim from the controls.
T
TOYSTRY
The rest of the disassembling is too difficult to document as I stopped take pics throughout the process. If during reassembling I have time, I'll try to reverse document it.
T
TOYSTRY
Before using butane torch to separate them (you won't be able to wrap it right if they are connected).
The silver dash pieces is melted to the black pieces. You have to use butane torch to heat them and separate them.
T
TOYSTRY
This was probably the most difficult thing to do (separate the stereo pieces). On this piece, the way they melted them together made it impossible to remove easily. In all honesty, I'm not sure whether or not I'll be able to melt/glue these pieces back together properly. Time will tell after I wrap them and go to reinstall.
T
TOYSTRY
Well I finally got it all finished and put back together. I had to redo the entire dash after doing it the first time, which means I had to uninstall, reinstall, uninstall, reinstall to get it right to where I was happy with it.
The first time I screwed up BIG TIME and didn't get the pieces lined back up right. Since you have to melt the plastic pieces apart from the backside, getting them to go line back up and then melt/glue them back together was a LOT HARDER and a LOT MORE WORK than I anticipated but it's finally right and I'm pretty happy with the results.
NOTE: If you asked me if I'd do this again, this answer would be NO......HELL NO.
Anyway, here are pics of the door completed:
T
TOYSTRY
Here is the center console and stereo completed. This was probably the hardest thing to do. Vinyl wrapping was the easy part.......seriously, it's stupid easy to vinyl wrap and I had no experience prior to doing this. It's getting the pieces that you had to "unmelt" to melt/glue back together that was the PITA.
T
TOYSTRY
The steering wheel is probably the main reason I wouldn't do this again. When I was removing all of the SILVER pieces, I was able to pry out the steering wheel controls without removing the airbag, however I wasn't that lucky when reinstalling. I tried to remove the airbag cover on my own following a youtube video and a how-to post from the Silverado forum but after 3 hours or failing to removing it (don't try, it's not worth your sanity) I ended up taking the Tahoe to the dealership to have them remove the airbag and reinstall the steering wheel controls ($90 was the cost to uninstall airbag, reinstall airbag).
I also vinyl wrapped the bowtie emblem on the steering wheel as well....a bit time consuming but I think it's looks much better. I had to carefully cut along the chrome edge of the bowtie and then use a heatgun to ensure the vinyl covered the ugly gold completely. I think it turned out nice, but I wish I had a piece of black vinyl instead of the brushed vinyl but I wasn't going to order a roll of black for a 3" bowtie.
T
TOYSTRY
And the last two pieces, which were a PITA to realign and piece back together was the A/C vent covers......what a PITA. Seriously, I wouldn't recommend to anyone to do this as it's a LOT of work and the pieces will NEVER look the way they did before you disassembled it. I got it looking damn close, but I can see the difference. Most wouldn't be able to though, but I'm picky and am very critical of things I do.
LGSONE
Looks great, but wow, what a ton of work. Very unique and classy looking. Great write up and good pic's for other doing other projects, stereo, wiring etc...
LGSONE
T
TOYSTRY
LGSONE
Thanks. I typically do threads on any modification I make to share with other but this is the most DEAD forum of any forum I belong too. I thought there would be a LOT more activity, maybe there is a different forum I should be visiting, if so, let me know because I love seeing what others are doing to their vehicles, and so far this forum has been as much fun as watching paint dry at times, lol.
LGSONE
For our year vehicles this is not a very busy site that is for sure. But looking at the thread counts on the OBS and NNBS Tahoe's it is much busier. That is the only reason I continue here. I do wish it was busier but the active owners of our year vehicles is certainly a minority. I can say seeing your post is just what this place needs. I have yet to find a very active forum for Tahoe's and this one seems to have the biggest user base so I guess time will tell.
To your post, I was showing my wife and she was wondering if you were married and what her reaction might have been. My wife and I tore here 2015 Cherokee all apart to do a front camera and a Uconnect hack to her truck. She was totally in shock when she came home to see it all in pieces.
LGSONE
T
TOYSTRY
LGSONE
Ya I'm married but the wife doesn't know I tore the vehicle apart.....best part is that I bought the Tahoe for her and she hasn't even seen it yet. My wife and I live apart (military) so tomorrow she flies in to pick it up and drive it (along with our dog) across country from VA to CA. The funny thing will be when/if she realizes I disassembled the entire vehicle to vinyl wrap it which I'm guessing she will realize quickly since her friend that she lives with owns an IDENTICAL Tahoe, same model, same color, same everything. I'm not saying anything until she ask and is far away so I don't get the "speech"....lol.
With that, when I was younger (20 years ago) I worked at Circuit City installing car audio and alarms so I'm familiar with tearing apart interiors so I had faith in my ability to do what I did. Would I do it again....NOPE. Wasn't worth the time and at the end of the day you "Do Damage" the pieces when you take them apart but I did a pretty damn good job of minimizing the damage to where nobody but me would ever know.
Hodmjstone
