3/6 from tony
Wicked Mayhem
installed the 3/6 kit this evening. Haven't drove it much. Need to trim rear fender liners.
Fosscore
Like the stance and that blue. Tidy free travel mod. What are you sitting ground to fender lip measurements? Might be able to remove the rear spacer, if you have it in, and get her down another 1 inch or so with maybe a crank on the front keys if you are interested. I did that to mine with the same kit. Wheels and color match look good. :waytogo:
NathanJax
Vacation Nathan
Jax, Fl
looks good
Looks good as always, man! :waytogo:
BADRIDES
Per title and original post it's a 3/6. I.e. 3" drop in front and 6" in rear
yeah I read the title. thought 6 in the rear would be lower looking than that.
W
Wicked Mayhem
33" driver side front and rear. Pass side is like 1/2" higher. I don't have the rear spacers in. Pass side key doesn't even have the torsion bolt in it. Not sure what's up with that. If the rear settles I guess I'll do drop keys and crank them up some?
Fosscore
Sweet man. That's right about where mine is sitting at the corners.
08grey
Wow. The free travel came out clean. Makes mine look like I did it with a ax.
W
Wicked Mayhem
Actual front drop is 3.75" on driver front, 3-1/4" pass side.... Rear, idk if the springs need time to settle, cause it only dropped 4.375" driver, 4.25" pass. with no spacers. Had to pull sway bar end links off and bend them because the sway bar was rubbing the shock. Trimmed rear fender liners today too. Everything else seems to be good. Just want to fix the Chevy lean. Snapped a few pics while putting some miles on it earlier
One clean NBS for sure! :waytogo:
BADRIDES
Be glad the back isn't dropped anymore or you would be squatting in the rear.
W
Wicked Mayhem
Thanks!
Still dirty, but a couple daytime shots. Took the long onstar antenna off and put a little cap on it. Little more sleek. Got about 110 miles on the drop now. Rechecked all the bolts etc. alignment Tuesday.
NORCAL SS
SUV SUSPENSION GURU
also the rear springs will ride better than any others out there at the height. I spent time dialing them in years ago
BadDaddy2003
