2004 white Denali XL part out
Status
Not open for further replies.
crazycoupe
crazycoupe
Rollin Low
Las Vegas NV
Yep that's it.all the tabs are intact and good condition? much u want for it and the zip is going to 11357
In perfect condition besides a little bit of the coating is peeling around where the bezel goes. $60 . I'll look for a box this weekend and get you a shipping cost. It is large so I have to assume it will be no less than $30 but i have been surprised before. Let me know if that sounds good and i will start looking for a box
Seats sold
wolferine358
That sounds good.let me know when your ready
Tiki
Mirrors? PM me if available. Shipping to 77494.
BOSTON5283
Im parting out my denali , I would rather not ship large items but if you want to pay its up to you. Im in Las Vegas NV
PARTS THAT I DONT HAVE
Engine
Front bumper, fenders, and grill
window motors and door handles
Clock spring
side mirrors
Cluster
head lights
running boards
All else is available if you need any little pigtails from the interior harness or body harness LMK.
PARTS THAT ARE AVAILABLE have 150xx miles
Two front seat full electric with heaters, drivers side ripped , as well as the second row heated captains chairs. One has some holes $200 for all 4 seats.
The full center console $200
dash bezel $100
All four door panels no switches ok shape $50
Rebuilt Transmission and converter works perfect ( around 15k miles) $200
AWD Transfer Case works perfect no leaks $ 150
Driver and passenger air bag both light grayish color with module and sensors $150
Headliner that has opening for sunroof in ok shape $20
Complete sunroof with wiring $100
Clean white hood $ 40
Rear Bumper with tow hitch ( bottom plastic is missing, poor shape) $ 40
Core support complete with radiator, fan shroud , ac condenser , trans cooler, bolts $100
Front differential 373 gears $ 100
front drive shaft $40
Rear drive shaft $60
Full ,complete engine wire harness NO CUTS with ECU, TAC module, and gas pedal $200 obo
IF YOU DONT SEE IT LISTED JUST ASK
Do you have a front license plate bracket?
BubsXL
TN
Is the driver side window switch available? Also all the plugs that plug into it with say 6 or more inches of wire attached to them.
jcevans7
Friendswood, TX
looking for the rubber trim on the back liftgate. The one attached to the body not the actual door. Mine is all cut up. PM if you still have it please.
crazycoupe
crazycoupe
Rollin Low
Las Vegas NV
The weatherstrip right? I do have it make me an offer. I believe it will fit in a medium or large flat rate box $12-16 to ship.
BubsXL
TN
Which ones are you in need of? The engine harness is staying together not cutting that one up
Tne harness in the drivers door. Mainly looking for the plugs going into the window switch with about 6": of wiore attahced or just the entire harness cut as it comes into the door.
crazycoupe
crazycoupe
Rollin Low
Las Vegas NV
I looked everywhere. Don't have it
subieworx
This would suck, but if I pay for shipping could you get the hood in a box?
chadw
how about the front door outer lower mouldings? if available id like the front fender mouldings as well.
chadw
do you not have the pieces I asked about?
Status
schafer98
