Denali headlights
Eroracing
Hello everyone I was just wondering if and how easy it would be to change my stock headlights to the ones like on the denali (plug and play would be great) ? I don't want any hids or anything crazy like that just a way to get the stock denali look with at least as good as stock light output. I would also like to change out the lower light and blinker lens as it has dulled over the years. My vehicle is a 2003 gmc yukon. Any advice or links to help me find what I'm looking for would be great.... Of course money is always part of the equation so if I get stock looking results by using aftermarket and save a few bucks that would be great! Thx
Eddie
ezdaar
Chat Troll
Redneck central, Aka Houston
Pull your pins.
Remove headlights.
Put in denali headlights.
Install pins.
Done.
I highly recommend you pop the projector off the back and clean the projector lense.
They get cloudy after awhile,mcleaning them increases light output substantially.
E
Eroracing
So your saying I can just install them utilizing same bulbs and stock wiring? Should I just get the oem ones(they are very expensive ) or is there maybe a less expensive aftermarket option that is as good as oem keeping same styling? Sorry for all the questions just don't want to spend a bunch of money and regret my purchase!
ezdaar
Chat Troll
Yes, they ise same bulbs, and wiring. Just plug them in and go.
I ran 55watt hid's in mine with zero problems.
Just get a quality relay harness from retrofitsource.com
Find a good set of used ones, they pop up from time to time.
NathanJax
Vacation Nathan
Jax, Fl
before you put the Denali lights in, do a quick retrofit in them. You'll be more than pleased!
E
Eroracing
Retrofit? Sounds like more than I would like to take on! But for curiosities sake what do you mean by Retrofit? Bye the way found some denali headlights on Craigslist for $65 is that a good deal?
NathanJax
Vacation Nathan
Jax, Fl
E
Eroracing
I lost out on those headlights.... Someone got to them before me! And no way will I do the retrofit.... But those depos look pretty decent almost like stock denalis maybe I will pick up a set of those... Are those plug and play as well?
NathanJax
Vacation Nathan
Jax, Fl
yes but about 50% less light than your current OEM headlights. That's the point of the retrofit.
ezdaar
Chat Troll
Spyder and spec-d brand from amazon or ebay are very very VEEEERYYYY easy to retrofit with a kit feom retrofitsource and will give you susbstantial amount of useable non offending light.
Second and third row.
http://www.theretrofitsource.com/complete-retrofit-kits/application-specific.html
Pick your choice of headlight asemblys feom one of those brands and get that kit.
Dig deep enough and you will find matching turn assemblys.
Fyi, there a ton of pem denali headlights on ebay right now.
NathanJax
Vacation Nathan
Jax, Fl
Spyder and spec-d brand from amazon or ebay are very very VEEEERYYYY easy to retrofit with.
Thanks for showing up in here... Help him find the way
YukonXL04
The Riverboat
Arlington, TX
I can confirm how easy the spec d lights are to retrofit. It was my first one ever. I made my own projector mounting plates and used generic h1 projectors. I will say the housings are kind of cheasy. The housing itself doesn't adjust so you might have to shim it a little to fit the grill and hood lines better. But it is a very easy retrofit.
01Konvict
Boats n Hoes
Raleigh/SML
Depo Denali reps with plates on Mini H1s, then split the headlights and remove the amber = WIN!
CrackerJack135
